what offset are you're rims? do they clear the front struts or did you have to use spacers? just wondering as i have pondered getting some 16's or 17's for the street and keeping my 15's for track work.
hey mate, unsure of the exact number but i know there front wheel drive offset and 4x100 stud pattern so I'm running 25mm spacers/hub adaptors allowing them to fit, yep they clear the strut sweet (aprox 10mm from memory)
Could i get a more in depth engine specs?
Also a total rough price on how much it cost to build it including the gilmer drives.
Edited by cuzzo
  "smeetsy1" said:
How much did the spacers/hubadapters cost you?
not sure man, they cam with the car
engines what you see in the picture, all internals are standard as the ze internals are strong enough to handle plenty of boost as they are, head is standard at the moment but will be getting worked later down the track.
the cost can depend, the set up you see in the picture has had about 6000 spent on it, including the purchase of the block etc.
some nice racetech 100series for the front, bit large but il make em fit :eatlead:
also have had one the underbody resealed
and the new front mount, sized to fit in behind my valence perfect 8)
hoping to run about 18-19psi, see what happens when i get it dyno'd though, as for power figures I'm not too sure what to expect but will be happy with anything close to or over 200kw atw
