Simon-R32 Posted June 19, 2008 Report Posted June 19, 2008 What was can i go about doing this convo? ae71 stuff is too hard to find so that rules out any bolt in stuff, also ae86 peddle's are getting hard to find also. has anyone used the existing ke peddle and modified it to work a hydraulic master? Quote
anastasios Posted June 19, 2008 Report Posted June 19, 2008 just find 71 stuff its probably a million times easier Quote
Medicine_Man Posted June 19, 2008 Report Posted June 19, 2008 What he said.. ^^^^^^^ But if you do find a way I'm sure lots of people will be interested.. http://www.rollaclub.com/faq/index.php?tit...ydraulic_clutch Quote
Simon-R32 Posted June 19, 2008 Author Report Posted June 19, 2008 yeah i saw that link you made thanks mate, very helpful. I have no doubt the ae71 stuff is piss easy, I'm just having a LOT of trouble finding the parts! Quote
fusion Posted June 19, 2008 Report Posted June 19, 2008 You could always weld on a hydraulic clutch to your original pedal box, drill a hole, and connect up the master cylinder. Its what I did in my KE30 and done it to an RA40 :lolcry: Quote
SeptemberSquall Posted June 19, 2008 Report Posted June 19, 2008 You could always weld on a hydraulic clutch to your original pedal box, drill a hole, and connect up the master cylinder. Its what I did in my KE30 and done it to an RA40 :lolcry: if you have a factory option like ae71 into ke70 you should do that what car is this for? Quote
