Is there any difference between KE30 Brake Boosters to KE55 Brake boosters?
Can the KE55 master cylinder go onto the KE30 brake booster?
Would the KE30 brake booster even bolt onto my 1981 KE55 hardtop?
Sorry about the nub question.
They are interchangable,.....if you swap the whole lot!!!
Ke30 MC is long and skinny, with either 2 resivours on top, or one on top and one on the strut tower.
Ke55 MC is shorter and fatter and has the big square resivour on top.
The '55 one is the better of the two, although there's not much difference.
A '30 MC won't fit a '55 booster and vice versa, as the '55 one has offset bolts. :lolcry:
if your gonna upgrade your MC at anytime i belive its better to use the ke30 one, as the bolt hole spacing is the same as the pajero MC alot of people use when they run bigger brakes. Its also the same spacing as an ae71.
Thanks. There is a reconditioned KE30 Brake Booster I found, though I might not hassel changing over everything.
Thread can now be terminated.
