hey all just picked up a ke70 for $200
had a stuffed motor so i put my good motor into it
had a stuffed choke cabel but can't figure out how to remove it to replace it with my good one
any help appreciated
thanks :D
grub screw on the choke lever/knob, remove the black plastic knob, unscrew the nut from the dash, pull choke thru into the car (once you've disconnected it from the carby)
install new one in reverse
