Raven Posted January 16, 2009 Author Report Posted January 16, 2009 (edited) Again had the brakes bled after I changed the seized front right caliper. The shop also fitted line clamps too to check the brakes. Brakes were fine, until I left and then the pedal went all spongy again, which means I still have air in the braking circuit somewhere. This is all being fixed on Wednesday next week by SA Brake & Clutch. But today, I fitted an electric fuel pump, as I've been having vapour lock issues in hot weather. The pump works and I've started it in the driveway, but havent taken it for a run just yet. Idles a damn sight smoother though :y: Edited January 16, 2009 by Raven Quote
Raven Posted January 17, 2009 Author Report Posted January 17, 2009 And.... the pump failed. Took it back and got a Goss aftermarket mechanical pump. Also changed the front wheels with new RT104 rims from the wreckers with half decent tyres. Quote
KE30_KE35_KE55 Posted January 17, 2009 Report Posted January 17, 2009 Raven said: And.... the pump failed. Took it back and got a Goss aftermarket mechanical pump. Also changed the front wheels with new RT104 rims from the wreckers with half decent tyres. All most ready for the great ocean road cruise :y: Let me know if SA brake have any trouble with the brakes. Quote
Raven Posted January 21, 2009 Author Report Posted January 21, 2009 (edited) Brakes sorted! Pressure bled the brakes and vacuum bled the brakes at the same time to force the sludge buildup out of the rear lines and rear main line. A big thanks goes out to George at SA Brake & Clutch for that one! Now all that is left is to get the stereo installed and adjust the lifters a little and then its all done and ready! :P Edited January 21, 2009 by Raven Quote
KE30_KE35_KE55 Posted January 21, 2009 Report Posted January 21, 2009 Raven, Good news about the brakes, what a magic trip the Great Ocean Road cruise will be in this car :P Quote
Raven Posted January 21, 2009 Author Report Posted January 21, 2009 Haha, I wouldnt say magic, it still has alot of wind noise, the stereo install! Quote
dfunkt Posted January 21, 2009 Report Posted January 21, 2009 Raven said: Haha, I wouldnt say magic, it still has alot of wind noise. that's just your aircon....if you close the windows, it disappears a bit :P glad to hear you're (almost) all set for GoR. Quote
Raven Posted January 22, 2009 Author Report Posted January 22, 2009 Just bought some speakers, so should have the stereo wired in today and ready to go. Hopefully I can change the window regulator easily and then I'm more or less set to go. :P Quote
13BT_KE20 Posted January 22, 2009 Report Posted January 22, 2009 check my other spare door, its got a overrated brown door trim on it. PM me if your still interested in it Quote
Raven Posted January 22, 2009 Author Report Posted January 22, 2009 My interior is black, so not of any use to me :P Quote
Budowski Posted January 22, 2009 Report Posted January 22, 2009 good to hear brakes are sorted atleast you will get a chance to give her a giant shake down on the great ocean road :) i can grab the reg out of my ke25 if you really need it let me know Quote
Raven Posted January 22, 2009 Author Report Posted January 22, 2009 (edited) Stereo is finally installed. I've got a regulator here, just need to fit it tomorrow. Since I have the day off, it can't be too difficult I guess :) Edited January 22, 2009 by Raven Quote
