  • Replies 85
anything will fit into an engine bay....big or small.....theres 3 factors that contribute.
1. the size of the shoehorn
2. the size of the hammer
3. if a small hammer wont do it......use a bigger one....
(IE: 9 pound slegdy)
simple.
  • 4 months later...
Just an up date on the car
Motor has been stripped down for some work
which includes:
Modified block: oil galleries
Modified rod: polished, hardened, arp bolts fitted, balanced, multi drilled bearings
Pistons: CP forged Pistons 20thou over
Head: Port and polish, larger exhaust valves, Heavier springs, Tomei Pon Cams adjustable cam Gears, Arp head stud kit
Oil cooler has been fitted to the car
Map sensor for the microtech has been upgraded to a 3bar item
Nirtous oxide Kit fitted
Motor should be back in the car and run in by jamboree on the 17th and 18th September (***Well that is the plan, we all know cars***)
Chasing 380-430hp at the wheels
or who cares as long as it runs in the 11's
Edited by OKE055
  • 5 weeks later...
Finally the motor is back in and ready to crank. just have dump pipe and intercooler piping to go, so this weekend i'll be out running it in.
