Falken_KE30 Posted September 5, 2008 Author Report Posted September 5, 2008 what type of relay... actually, i don't even know how or what a relay does :) Quote
Taz_Rx Posted September 5, 2008 Report Posted September 5, 2008 I'll give you one tomorrow and explain how they work. :) Quote
Falken_KE30 Posted September 5, 2008 Author Report Posted September 5, 2008 O yes that works... don't have the $$ for the dash or stickers yet...but ill talk to ya about that tommorow.. On a side note, i got a thermo fan off a Camry.. have fitted it to the rolla, and it fits inside the standard shroud bit... so it all looks stocko. :) Quote
Falken_KE30 Posted September 6, 2008 Author Report Posted September 6, 2008 (edited) Motor is back in and all hooked up.. Havent started or driven it yet.. will do that tommorow as I'm fairly stuffed today lol.. Have got brake line fixed, and brakes all bleed.., Have got a relay for fuel Pump wired up.. sorta. Need to know what i can tap into for when i switch the key to "on" the pump runs.. the relay is near battery as its a Fuse type one. so i need to tap into a "on" wire somewhere in the engine bay, and the earth is pretty simple. Also, is there anything wrong with having a thermo fan on all the time while car running? Edited September 6, 2008 by Falken_KE30 Quote
ke20rolla Posted September 6, 2008 Report Posted September 6, 2008 I don't think they are designed to run constantly. Anyway I have a thermo fan on my weekend ke20 with the 5k motor and I have hooked the fan up to a toogle switch, and mainly turn it on when driving slowly, especially through town and stopping at traffic lights etc. :) When I'm on the open road I hardly ever use it. :yes: Quote
Falken_KE30 Posted September 6, 2008 Author Report Posted September 6, 2008 Yeah was thinking on doing that... Did you hook the fan and switch upto a relay? Quote
Falken_KE30 Posted September 7, 2008 Author Report Posted September 7, 2008 http://au.youtube.com/watch?v=YIZNCL2GKOs Quote
Falken_KE30 Posted September 7, 2008 Author Report Posted September 7, 2008 yeah i know... is rather lumpy.. not sure if its a stock cam, or a slightly lumpy one.. i know it does need a tune, and i need to advance the timing more i think. Either way its awesome!!! have to adjust the clutch i think, we i put pedal down 3/4 way its disengaged completly, but if i put pedal to floor it whines really bad.. but the whine gooes away if i only go 3/4 of the way.. the clutch still grabs and works fine though as you can see. Quote
roladude Posted September 7, 2008 Report Posted September 7, 2008 you suspesion looks pretty stiff the car didnt move much going down the gutter :wink: lol at burnout on rental property driveway :D you must have good neighbours not to complain Quote
Falken_KE30 Posted September 7, 2008 Author Report Posted September 7, 2008 http://au.youtube.com/watch?v=0q526OKRlOo (and yes it was done on private property... aka a cement slab in backyard where a shed was LOL) and yeah the neighbours are sweet.. there a noisier bunch down the road... And yeap the suspension is pretty stiff.. i noticed it didnt move either... Quote
Taz_Rx Posted September 7, 2008 Report Posted September 7, 2008 Falken_KE30 said: ......... and the earth is pretty simple. :wink: :D Quote
Falken_KE30 Posted September 8, 2008 Author Report Posted September 8, 2008 shut up SI.... i know the pump stopped cause my earth was bad.... (insert sticking finger up here ) :D o wait there is one HAHA.. Quote
Taz_Rx Posted September 8, 2008 Report Posted September 8, 2008 :wink: Once you learn the importance of a decent earth, you won't forget it in a hurry. Electrical current (and sufficient sized wiring and earthing) is just like putting a set of side draft webers and a ported head on a motor with a stock exhaust manifold. There's no point in having a 'big mouth' - (fat wire etc) if you don't have a sufficently sized sphincter!!!! :D Speaking of which, how many earth straps do you have on the motor? at least 2? Quote
Falken_KE30 Posted September 8, 2008 Author Report Posted September 8, 2008 1 i think..... was going to add a second but forgot too Quote
