  • Replies 1.1k
Also guys a semi-long shot here
A mate of mine is trying to track down contact details of the owner of a Blue WRX wagon/hatchback, number plates are REX-20R or there abouts
Any help would be greatly appreciated
got new rubber on the ma61's
185 60's streched over a 8'' 14
did ma61's come out in 8 inch because on the rim it says ra ra ar 8* they look fattttt as
putting them on now
pic up later
there waiting 4 but it says ur outta office...
compression tested my car today
1: 130psi
2: 130psi
3: 128psi
4: 120psi
that alright yea?
You normally average +/- 10psi but 120 seems to be getting a bit low for a bigport gze, How many times did the engine crank, I let it turn over 7 times when i do a compression test.
nah man i got the specs from toyota 146 is minium or something around that and no more than +/- 8psi, for a good engine on a 4agze bitport
yeah i'd probably turn them over a bit more at least 5 or 7 like trev said
me and gregor did mine and i got 130 and on the first cyl and straight away i knew it was a dud engine
do a wet test as well, throw some oil down the bore then comp test
i only let it crank about twice or so
should i do it again?
wats the norm for a gze?
Yeah do it again, Mine had 150 which is what you'd expect from a 8.0:1 CR.
