Corolla1 Posted June 27, 2008 Report Posted June 27, 2008 you can nearly always run an engine without a fan the only time you need a fan is when you are stopped in traffic if your thermostat and water pump is good. you wont have a problem till you stop moving. Quote
st.nick Posted June 28, 2008 Report Posted June 28, 2008 Thermo fan... f@$k all the thermoswitches and stuff, just wire it to your ignition. I had mine wired into my ignition, so it was on whenever the car was on!! I too the front fan off my engine, and only ran with the thermo fan. No problems, easy, and no forgetting to switch it on or off!! My Corolla just had a 32/36 bolted on, and so far, so good!! Not sure on what jets, not sure on fuel economy... but it is a little bit faster than it was, and hangs the arse out better!! :P Quote
Palmy Posted June 29, 2008 Author Report Posted June 29, 2008 (edited) Thermo fan... f@$k all the thermoswitches and stuff, just wire it to your ignition. I had mine wired into my ignition, so it was on whenever the car was on!! I too the front fan off my engine, and only ran with the thermo fan. No problems, easy, and no forgetting to switch it on or off!! My Corolla just had a 32/36 bolted on, and so far, so good!! Not sure on what jets, not sure on fuel economy... but it is a little bit faster than it was, and hangs the arse out better!! :P yeah well i was thinking that but i would prefer it to be turning on and off when desired, as stated earlier in thread it may take a lil longer 4 engine 2 warm up and possibly drain power. the noise may also get annoyin when idling. as for the weber, it would be really helpful to kno what jets u r running. as i have no bloody idea what to put in mine! its good to kno that the 32/36 makes a bit if a difference though, do u have a nice induction sound to go along with it? lol oh and does anyone know/reccomend which of the switches in the tridon switch catalogue would best suit me? help with this would be awesome!! Edited June 29, 2008 by Palmy Quote
