Trev Posted April 26, 2008 Report Posted April 26, 2008 demotorsport said: crank/pump seal is done same as the cams seals so pump stays onso far so good no oil leak there anymore now the new cam seals are pissing out so bad it leaves a puddle of oil under the car(not drivable) can some1 confirm i have correct cam seals with a part number PLEASE????????????????? and any tricks or do's and don't wwhen doing installing the cam seals??????????? cheers Refer to PM, Also the seals are the same between smallport and bigport, I put small port ones in mine as thats what i had. Quote
