toyota_ae71 Posted April 5, 2008 Report Posted April 5, 2008 hey people i was having alook on jap yahoo just to see what was on there and found this cam but..... i can't read it LOL so if anyone knows how to change or read and tell me how much i'd be really happy :abuse: TRD CAMSHAFT Quote
silent_witness Posted April 5, 2008 Report Posted April 5, 2008 Yeah i wouldnt mind also knowing what most of that said, as i have seen some very very VERY nice stuff on yahoo japan :abuse: Quote
Trev Posted April 5, 2008 Report Posted April 5, 2008 Yeah i wouldnt mind also knowing what most of that said, as i have seen some very very VERY nice stuff on yahoo japan :abuse: K Series TRD Camshaft In English Try that. Quote
camerondownunder88 Posted April 5, 2008 Report Posted April 5, 2008 Will be A LOT of work to fit a TRD cam shaft: Stock cam on left TRD cam on right. Notice the bearings for a TRD cam are HUGE and the lobes are longer. Will need to bore out bearing area of cam and fit larger bearings if you get that cam. Or just get a stock cam regrind it to what suits your car and done..lol Much cheaper. Cameron Quote
Clapped out Posted April 6, 2008 Report Posted April 6, 2008 Looks like that trd cam would also need matching gears and chain to suit aswell, cheers phatke30! Quote
camerondownunder88 Posted April 6, 2008 Report Posted April 6, 2008 You got a good eye phatke30 The TRD cam doesn't use a chain. They use solid gears like Holden motors. small bracket with bearing holds gear bolts onto block and new crank adn cam gear fitted. Cameron Quote
Medicine_Man Posted April 6, 2008 Report Posted April 6, 2008 Like this picture shows.. For what it is worth, You would be better off getting a standard cam reground to spec as we have better technology these days when it comes to cam profiling.. Quote
Taz_Rx Posted April 6, 2008 Report Posted April 6, 2008 What with that centre gear MM???? is that a TRD item or something? Or is that very much custom? Quote
Sam_Q Posted April 7, 2008 Report Posted April 7, 2008 damn that would be a noisey setup! I know some people would be horried by the sujestion but in concept couldnt you give the cam to a lathe grinder and take the bearing size down to stock? why do you think they did it anyway? to reduce head wear? Quote
camerondownunder88 Posted April 7, 2008 Report Posted April 7, 2008 TRD gear drive system is an off the shelf can buy option Taz that isn't custom. Also TRD 3K I believe can bounce around the 10,000 to 11,000 RPM mark. At 11,000 RPM cam is doing 5500 RPM stock cam only should go to 3150 RPM so I guess they run bigger bearings to help with load more oil film around it and surface area for oil to work on. And the trust face is bigger so I dare say the gear system put extra axial load on the cam shaft. You could grind it down to size no worries. But I think with a reground cam you can get a way better cam profile and keep the TRD one for a collectors item hang on the wall..lol Also the TRD 3K had 150 HP and bigger valve springs so I would also hint the extra valve spring load might of made them run bigger bearings. Cameron Quote
madrolla68 Posted April 7, 2008 Report Posted April 7, 2008 What with that centre gear MM???? is that a TRD item or something? Or is that very much custom? Yep me too want to know more. :dance: :hmm: Quote
Medicine_Man Posted April 7, 2008 Report Posted April 7, 2008 It is a weak link, Stick with the double row timing chain............. Quote
SLO-030 Posted April 10, 2008 Report Posted April 10, 2008 What with that centre gear MM???? is that a TRD item or something? Or is that very much custom? do you mean whats it there for?? CHEERS Ryan Quote
Medicine_Man Posted April 10, 2008 Report Posted April 10, 2008 Yes that there is the genuine TRD 3K gear.. Quote
Philbo Posted April 10, 2008 Report Posted April 10, 2008 The centre gear would allow the cam gear to rotate in the correct direction. It spins the same way as the crank gear. (Imagine the chain drive) Quote
