  • Replies 131
yea i will once i build the ae71 4age i will sr20det the ke70 and use it as a track car, and when thats done i will turbo the ae71 4age
then i will get myself a s13!
but yea thats the plan
Travis
Travis
Sounds like you plan to earn a lot of money as well LOL
It's good though, go after what you want at your age and you wont be dissapointed that you didn't later in life :wink:
Thats what i reckon, and what i want in life is to make it into drift australia, that would be tops!
but yea thats a while off, hopefully not too long though. can't wait till yours is on the road
Travis
hey mate you gonna be painting the bay yourself?
Hey Luc
Me and a couple of other helpful hands are going to do the prep and priming but seeing as the colour i chose is metallic, i will probably enlist the help of a pro to actually spray
Unless Mick is feeling up to the challenge? :wink:
Hey Luc
Unless Mick is feeling up to the challenge? :P
give it a shot yourself!
the engine bay doean't have to be 100percent you don't see most of it!
be a good experience!
a little tricky in some areas but if your patient you can work your way through it!
mettalic won't matter so much in an engine bay.
there are that many different angle that you won't really notice if the metallic falls wrong!
i did my engine bay on a hangover and it was the first real thing i'd sprayed!
although i didn't use a metallic paint!
i did however put metallic in the clear!
what type of paint? acrylic or 2 pac?
for the rest of the car a pro is a good idea though!
Yeah the body will be pro sprayed when i save up the coin and get to that stage on the list
And the colour is only available in acrylic unfortunatly, I would have preferred 2 pak
acrylic is perfect for diy!
if you stuff it up its really easy to sand!.
my car was sprayed with acrylic and the bay too!
most new cars are acrylic now aswell!
just use a 2pac clear coat! in fact all new holdens and fords are acrylic with a 2pac clear.
So you can put a 2pak clear over an acrylic? i got told you couldn't but the guy wasn't too sure
don't believe what some people say, i got told to put an acrylic hardener over my enamel paint aye, idiot haha, but yea you spray a crear hardener over it and she is solid as bruh, 2 pac you will find is extremely toxic i think you will find and you need like a full body suit or something like that to paint it.
but yea do it yourself, sprayed my entire car with spray cans and it turned out great even though i did absolutely 0 prep, if i did it would have been perfect, i used the cheapest of cheap cans from bunnings haha, i don't recconmend it though unless you want to spend extra prep time and don't want a mad finish like you get with acrylic.
Travis
definately!
my car is an acrylic basecoat with a dupont oe8000 2pac clear coat!
the basecoat coulour being acrylic makes it really easy to put on!
once that is perfect put about 3 coats of clear! buff and it'll perfection!
glassy mirror type finish!
alot easier than tyrying to use 2pac for the colour straight up!
Yeah i'm pretty much going for a nice clean streeter (a couple of pegs below show car) so i definatly wont be spraying the body myself
I know you have to put a clear over the acrylic and if i can put a 2 pak clear on then it will be much stronger, however i want to be sure the 2 pak thing can be done before we do it
Cheers - Andrew
Cheers - Andrew
mate i work at paint factory.
and i know exactly what went on my car!
and it works and that is how most new cars are spray painted!
also that is a very common method these days for a lot of things!
60percent o the work we do is that method!
Awesome,
Well that definatley sounds like the go then
That makes me feel better, and i wasn't doubting you Luc just checking all my info mate :P
