  philbey said:
Mind if i ask what those rims stung you? They're pretty tidy looking!
They're the same wheels my KE25 is going to end up with....Konig Rewinds :)
  • Replies 36
Hi mate love the car looks very tuff, i was hopeing you might be able to help me by measureing your swaybar thickness as I'm wanting to know the difference beyween ke36 and ke30 sway bars as i want to go thicker mine is 19mm. Any assistance would be appriciated. :hmm: Thanks.
The 2TG came out of the TA22 GT series, LT series had 2TC engines (single cam, single carby etc). They cost over $1000 rebuilt, but can be picked up for around $300 at lowest for an engine in need of rebuilding. They can make over 130KW, just with a slightly ported and polished top end.
  smeetsy1 said:
SeptemberSquall, may i ask you how you did your engine mounts?
custom?
inside info says te37 x-member with factory 2tg mounts
what a load of bs
factory hp was 125 hp in the highest tune version *gross*
generally an average one makes 55-60rwkw std in early corolla or celica rwd
built one with a friend which was 3t crank, roughly 1810cc, 304/288adv @ .395, 10.5:1 and made 88rwkw with 40mm phh
went to 45 dcoe and made 97rwkw
now running dcoe throttle bodies and wolf engine managment still 98rwkw
i'm hoping for 100-115rwkw out of mine at 1941cc
anyone who reckons they are making 130kw out of the stock 1588cc is using serious forced induction or too many magic mushrooms
  glenn 87 said:
any plans for a grill? or just going to leave it off?
was thinking about leaving it off
now i've retrofitted an rt132 item
was at a self-serve wrecker grabbing some other bits and just happened to find it there and it was close to the right width and easy to mount
not sure if i like it tho
looking for gc ke55 guards if anyone has any
