  • Replies 386
Been a while since I've read this thread, but what are you planning on getting after letting this go?
Love the bosozoku look. :yes:
ke70 wagon, low as on fatass mrk 3s, 4agte or maybe sr20. will be turbo whatever i get
well this is going to be up for sale after i get my loom rewired, selling as I'm keen to start a new project
will be looking for $6500 compelete as it is, it has rego on it but not engineered so if you get a dodgy rwc you can transfer it. if not i will cancel it
or 6000, with stocko rims will take another 200 off and quad headlights come off and adm goes back on
Engine/ engine mods
bigport 4agze, its got higher compression then standard so might of had some work done
ae92 map sensor loom and computer
165mm pulley
tuned length extractors
pod filter
intercooler with 2inch pipping
rb20 radiator
button puck clutch
vl lift and high pressure pumps
under car surge tank
Kouki brake disk diff with trd 2 way, 4.3 with braided brake lines
Suspension
front coilovers with 6.7kg spring, ky agx shocks
s13 camber tops
peugoet/ hilux brake upgrade
new brake lines
pajero master cylinder
ae86 lcas with good bushes and balljoints
brand new tierods and rackends
cut stocko and trd green for the rear
body
quad headlights
dx taillights
interior
ae86 jdm steering wheel
2inch boost gauge
2inch air/fuel mixture
ae71 tacho dash
dildo shifter
blue interior
wheels
15 x 7.5 +17 SSR forumla mesh
15 x 7 +24 SSR Forumla mesh
running 195/50/15 bridgestone re001s
cheers andrew
Edited by Roo
You can't sell a car without rego so unless you don't want a new owner rolling around with a car registered in your name until they get it engineered so they can get a roady i suggest that you either cancell the rego or get it engineered and sell it for a little bit more.
i know that, i will reword it.
