Ok lets look at it like this there's the window and my clutch is allmost out of it.
A friend told me adjusting the clutch cable would give it a bit more life until i save enough for a new one.
true?
if so how?
cheers,
logan.
also like to add since signing up here i've learn't so much more about cars than i ever would and would like to thank all the members, mod's, admin etc. here on rolla club.
Adjust it at the cable clutch bell on the firewall, You will see when you look closely it has a circlip holding it out. Pop the circlip off and pull the clutch cable out as far as it will let you, Then pop the circlip back on.
Clutch for a 4K is pretty cheap, like $90 for a kit, Save your sanity and do a weekend swap if that is the problem..
ok so i went and had a look and no luck
i have slim to none idea of what your talking about i think i know where the cable is but where is this clip and how do i undo it?
logan.
