I've been poking around in the dash of my KE35 and have discovered a few wires that aren't connected to anything. I've got a Gregory's Corolla 1970-1978 manual but my wiring doesn't match anything in the manual. It's an Australian built 1978 KE35 CS Hardtop. The main reason I'm asking about them is cause I plan on installing factory A/C at some point and will need to know what wires to hook up.
Does anyone have the correct wiring diagram for this Rolla?
I've attached some photos of the wires I'm talking about.
The first wires are dark green and dark green with black trace and they are between the fuse box and the steering column.
The second wires are between the AM radio and the instrument panel and are red, red, black with white trace, black with white trace, white and green. The 2 black with white traces are looped together.
The third wire is a blue with white trace and comes from the heater/fan.
The forth wires are light blue, black with white trace, black with white trace, and red. and are just above the heater/fan.
that is perfectly normal Toyota run extra wires for factory or dealer fitted tape decks, Air cond .
The loop looks very much the same as the neutral safety switch loop used on a manual. on a KE30 it is found under the R/H kick panel.
Edited by KE30_KE35_KE55
The last pic is for the rear speakers. you will find the wires end in the boot under the parcel shelf.
2nd pic is the neurtral cut out for automatic versions... use that loop for an immobiliser circuit.
Hit up BradW on toymods he has a copy of the factory wiring diagram which is really clear.
Cheers guys, I was aware that Toyota will use one harness to do all versions of a model of car.
The original AM radio/cassette player wiring was hacked up by the last owner as he had no idea what he was doing when trying to install a CD player. The wire that are for the A/C and if any of the other wires are for the cassette player are the main concern. I was just curious about the other wires in case they are other accessories I might want to hook up in the future.
I have seen a set of dark green leads unconnected in the boot and in the Gregory's manual it has a diagram for late models that has one speaker for the AM radio and 2 speakers for the cassette player. I'll talk to BradW and see if he'll send me a copy of his diagrams.
Cheers guys
Cheers to those that helped with identifying my wires. What I've worked out/been told is: the first wires are speaker wires for if the car just had the AM radio with single speaker; the second set of wires are for the auto gear box if I had one; the 3rd wires are for A/C; and the 4th wires may also be for A/C (need to reference BradW's diagrams again).
