corolln Posted February 24, 2008 Report Posted February 24, 2008 my problem... my brake lights both work fine but when my taillights are on one of my brake lights doesnt work why could this be... is it a wiring issue?? how can i fix it... cheers Quote
Medicine_Man Posted February 24, 2008 Report Posted February 24, 2008 Do you mean when your park lights are on one of your brake lights doesn't work when you apply the brake pedal? (I'm assuming all the bulbs work fine?) Kind of sounds like a bad earth to me.. Quote
corolln Posted February 24, 2008 Author Report Posted February 24, 2008 yeah thats it.. when i apply the pedal the right brake light doesnt work.. but the brake lights work find when the parking lights are off... so blubs are not the issue... where do i check for a bad connection?? Quote
toy74 Posted February 24, 2008 Report Posted February 24, 2008 Have you recently had the lights out or painted the car? you may need to check the earth wire, maybee scratch a bitt of paint off where the earth wire connects to the body and reinstall. Quote
Medicine_Man Posted February 24, 2008 Report Posted February 24, 2008 use a test light from a ground point to where the bulb grounds out, If the test light is dull then you have a bad earth, if the test light doesn't light up the earth is good.. Quote
KE30_KE35_KE55 Posted February 24, 2008 Report Posted February 24, 2008 what do all the light spades terminals look like ? I saw a NOS after market light base that the terminals had turned green whilst still in the box. I hate cheap Crap. if they are dirty clean them. Quote
corolln Posted February 24, 2008 Author Report Posted February 24, 2008 where is the earth wire to check.. is it the two ground wires in the boot.. i have recently resprayed this area.. but it was happening prior to this.. so i am lost... Quote
Medicine_Man Posted February 24, 2008 Report Posted February 24, 2008 You earth from the body of your car to wherever the bulb grounds in the bulb holder.. Quote
Hiro Protagonist Posted February 24, 2008 Report Posted February 24, 2008 corolln said: yeah thats it.. when i apply the pedal the right brake light doesnt work.. but the brake lights work find when the parking lights are off... so blubs are not the issue... I guarantee 99.9999% that the bulb is stuffed. Replace it (they only cost 50 cents or whatever), and all should be sorted. I had the exact same problem with my 102 - when headlights were off, both brake lights came on normally. When the headlights were on, the tail-lights came on normally. But when I braked with the headlights on, the brake light wouldn't come on and the tail-light would go out. Turned out the elements in the bulb had stretched and shorted to each other, so you could have current running through either one of them fine, but if you had it through both then it would short out. Quote
xdave Posted February 24, 2008 Report Posted February 24, 2008 (edited) is the bulb base and/or the connector corroded at all? it kinda sounds like that brake light is chasing an earth through the park light circuit you can try the new bulb idea - along with that (if that doesn't work) what i did to jury rig it when i had this exact same problem (because the connector was corroded to shit) was wrap a piece wire around the base of the bulb twist it tight, plug the light into the hole and then unwrapped some tape around the earth/neg wires and hooked it up there. passed rego for me anyway :P Edited February 25, 2008 by xdave Quote
corolln Posted February 25, 2008 Author Report Posted February 25, 2008 sused it a bit more.. scrathed paint of so it has a better ground conection.. then had a closer look at the bulb and only one of the coils is lighting up and it is quite dull compaired to the other bulb.. does it sound like it just needs a new bulb?? cheers Quote
Medicine_Man Posted February 25, 2008 Report Posted February 25, 2008 corolln said: sused it a bit more.. scrathed paint of so it has a better ground conection.. then had a closer look at the bulb and only one of the coils is lighting up and it is quite dull compaired to the other bulb.. does it sound like it just needs a new bulb?? cheers By all means do the simple fix first!!! Whack a new bulb in and let us know how you go.. (I was under the assumption you knew the bulbs were good).. Quote
corolln Posted February 25, 2008 Author Report Posted February 25, 2008 Medicine_Man said: By all means do the simple fix first!!! Whack a new bulb in and let us know how you go.. (I was under the assumption you knew the bulbs were good).. ill do it tomorrow... see how it goes... i did check the bulb quickly look alright but had a closer look at it today Quote
xdave Posted February 25, 2008 Report Posted February 25, 2008 if the tail light that is still working is dimmer than the other side, i would say its probably a crappy earth issue Quote
corolln Posted February 25, 2008 Author Report Posted February 25, 2008 (edited) yeah i sussed the eath out.. well the two locations i can see where it is earth out in the boot and there fine.. so ill get a new bulb today n if that doesnt do it well I'm lost.. Edited February 25, 2008 by corolln Quote
