dfunkt Posted February 19, 2008 Report Posted February 19, 2008 i picked my 5k up from an old ke35 cruiser. $300 for the whole lot. Quote
Raven Posted February 19, 2008 Report Posted February 19, 2008 Got my 5K from a KE70 panel van at a self serve wrecker. Pulled the motor out myself and it came with an electronic dizzy for $180 :P Quote
Doogs Posted February 20, 2008 Author Report Posted February 20, 2008 Thanks coln72, dfunkt, Raven Good to get an idea on the price :P Quote
philbey Posted February 20, 2008 Report Posted February 20, 2008 i picked up one disassembled for 100 bucks. Given some of the crazy prices seen here, that might be considered expensive: But at least I know what knick the internals are in and I can rebuild as I see fit. This is a fantastic thread by the way, given that I'm deliberating over where to spend my money on the aforementioned rebuild! Quote
Doogs Posted February 20, 2008 Author Report Posted February 20, 2008 (edited) philbey, do you know where pete robinson sources his 5ks? Or even a good wreckers in melbourne for them ? I have been down to centre road wreckers, but they only had 1 KE20 and that was it rolla wise. Better still, where did you get yours ? Edited February 20, 2008 by Rad Rolla Quote
philbey Posted February 20, 2008 Report Posted February 20, 2008 No idea where pete gets them from, but I think talking to him in the past he knows an importer or something. Last time I got a price from him, It was about 600 or similar, which I thought I could improve on. kangaroosa might know more though. Theres two Toyota import joints to try: one on Chesterville road, Moorabbin, and theres one on Edelmaier street Bayswater (Generally expensive) As for mine - I got it off here. There have been some good deals on them come up in the last few months, so watch those sale threads and you will need to be quick. Quote
Doogs Posted February 21, 2008 Author Report Posted February 21, 2008 Cheers philbey, I will get in touch with pete at some stage soon to disscus some of the engine related stuff. I will talk to kangaroosa closer to the time Dougal Quote
Doogs Posted February 21, 2008 Author Report Posted February 21, 2008 (edited) Ok, what else have you other guys got ? Anyone who has not put their specs up, now is the time ! Cheers Edited February 21, 2008 by Rad Rolla Quote
superbmobile Posted February 21, 2008 Report Posted February 21, 2008 super hyper stock 4ac FTL. Quote
coln72 Posted February 23, 2008 Report Posted February 23, 2008 Try a commercial wrecker for a 5K/7k since they came from liteace's. May find one. Quote
Doogs Posted February 23, 2008 Author Report Posted February 23, 2008 Thanks coln72, I just discovered toyrolla spares last night and will ring them at some stage to see what they have got. If not i will visit the local wreckers. Toyrolla spares I am now interested in putting on a 3k-b twincarb setup and so will see if toyrolla can get them in. Anyone have experience with these ? Quote
reg_ke35 Posted February 23, 2008 Report Posted February 23, 2008 (edited) Hey all, I have a mildly worked 4K consisting of, -20" thou shaved head -double valve springs -292 degree cam, around 420" thou lift -quite a nice port job -2 inch exhaust with extractors now needing some carbies to open the cam up. Reg Edited February 24, 2008 by reg_ke35 Quote
coln72 Posted February 23, 2008 Report Posted February 23, 2008 yes, both Cameron and myself are/have run these. Make sure you find a setup that is complete, as linkages and aircleaners are hard to set up if they are missing. I know :P Quote
Redwarf Posted February 23, 2008 Report Posted February 23, 2008 Hey all, -20mm shaved head Reg Reg, could I just correct you on a point of order? I think you mean .020" (20 thou) head shave. I had one down .125 (about 3mm) and that was a BIG shave. Normal programing may now resume..... :P Quote
camerondownunder88 Posted February 24, 2008 Report Posted February 24, 2008 Hi, Twin carby setups are NICE. I find good throttle response and allows a lot more air flow and motors become more responsive.. There nice. BUT Air filters not made for them now and to buy a setup with the original air filter box RARE as rocking horse poo. I have 2 setups int eh shed one with airfilter box but mmm crabbie carbies and then another complete original big port setup minus air filter box. Now if you run extractors the 4th cylinder runner usually hits the water cooling inlet line to the manifold so a lot of twin carby setups have this water line ground off from past owners. Hard to find a set untouched. but pacemaker extractors 4-1 for K motors I find down hit this water inlet so you can get extractors that wont touch. Also Linkages I can send you pics if you get stuck on how to assemble BUT if you don't get linkages with the carbies you will find it hard I can't find them anywhere as I'm missing 1 linkage part off one of my setups and can't find them. Also in my KE15 original setup the carbies have a slightly smaller needle and seat in the carby. The replacement needle and seat you can buy for twin carby setups is the larger size. I had a few teething issues with replacing my seats but I got there eventually with a mix of different parts so this can also cause issues. BUT if you want get 2 normal carbies easier for parts and a single carby has bigger jets in them. Run 2 of these on the twin manifold for a bit more grunt also. Cameron Quote
