Hey all,
I am looking at building a warm 5k in the near future to go into a
Ke15/17/20/25 (whichever i end up finding).
I have as good as planned what i will be doing to it (heads, cam etc) but
have decided to have a look at other options as well, and find out what
others are doing/have done.
I am interested to see what others are doing/have done in the
way of blocks, what head + work, cam, bottom end mods etc.
So;
What k motor do you have under your bonnet, and with what (if any) mods ?
What head are you using, (and what has been done to it) ?
What other work has been done to the engine, and to what specs ?
(cams, parts etc)
Sorry about all the questions, but i figured it would be good to see what else
is/has been done, and what combination of parts are being used.
By the way, i have read the faq article on 'how to build a tuff k motor' a number
of times, but figured it would be good to get an idea of how others have done it and a
few more opinions.
Thanks in advance,
Dougal
Edited by Rad Rolla
Hey mate,
I'll give you info on my 5k.
By the way. I bought it like this, and I'm almost finished putting it into my ke55 4dr, so i havent actually driven it yet, but here's what is done to it anyway.
-Head port and polish
-Duralite Pistons
-Fully balanced bottom end (crank, conrods etc.)
-Electronic Distributor
-10mm Stainless Steel Custom Leads
-Dual 40mm DCOE weber carburettors (Just Been Reco'd.) and soon to have ram tubes/socks.
-3 core radiator
-Thermo Fan
-Extractors
-One-piece Unknown size exhaust 2inch-ish?
- A cam that is 1/3 bigger than an a9x torana race cam? anyone got info on that?
Thats all i can remember for now?
Hope that was what you were after?
Nathan.
Cheers guys,
KE555k, sounds like a fun car you have got there ! :y:
(especially with that cam)
I have been told before that duralites are good pistons, do you know where
they can be sourced from + a rough cost ?
Thanks,
Dougal
Hypertech makes the duralite pistons i think? Correct me if I'm wrong.
I have currently sent my 3K to the machiners:
Mods are as follows:
Bottom End -
1.Balance Crank, Crank sprocket, Conrods, Pistons, Flywheel and Clutch.
2.Block Rebored and Honed 60 thou over.
3.Hypertech Duralite pistons and rings to match.
4.Shimmed oil pump.
5.Block refaced and head shaved to achieve 10:1 compression.
6.Heavy Duty Clutch
Head -
3K Bigport,
1.Match ported and polished to exact measurment of intake and exhaust gasket.
2.Bigger Valves.Custom Valve seats to match.
3.4K stems and retainers.
4.Heavy Duty Valve springs.
Others -
1.Cam regrind.
2.Distrubuter rebrushed and recurved accourding to cam specs and how much ron of fuel that
will be used.
3.Custom leads.
4.Bosch Gt40R Coil.
Intake & Exhaust.
SU HS2 twin carbs.
2 inch manderel bent extractors with exhaust wrap.
Thats about.
Bottom End -
4.Shimmed oil pump.
6.Heavy Duty Clutch
Head -
3K Bigport,
Others -
1.Cam regrind.
will be used.
3.Custom leads.
4.Bosch Gt40R Coil.
Intake & Exhaust.
SU HS2 twin carbs.
Thats about.
Sounds like a nice build :y: ,
If you don't mind me asking, what did all that cost ?
I am especially interested in the costing of your head work. I have decided
that this will be where i put most of my money into, because it is where i can
get the most gains.
I am looking at getting a port+polish job and hopefully bigger valves
with seats to suit. I need to look into this a little more though, because
I have heard that in a 5k head there is not space for this.
This is why i am interested in the different combos people have, incase
i need to run a worked 4k head on a 5k block. (or something similar)
What combos do the rest of you have ?
The head will be the most expensive in order to benefit the engine.
1. Match porting - $500
2. Bigger Valves - $330 (I think they needed to be custom made to fit the head, not very sure)
3. Heavy Duty Valve Springs between $200 - $300
Taz you boost junkie!!
Why don't you buy a car that comes with a turbo out of factory and leave the poor K engine NA and alone.
HAHAHA Kidding mate, looks like an awsome setup there.love the the chrome and blue colour combo.
4k (or 3k) head on 5k bottom end = low compression, ie suitable for forged induction only!! :y:
Under my bonnet.....hehe
Thanks man, that answers it for me :S
By the way, your bay looks top shelf :P
Do you know if there is any space for bigger valves in a 5k head ?
Thanks
Sweet, that was approx what i thought i might be spending.
(hopefully i can get springs cheaper than that though)
all you guys spending big bucks on pistons, balancing etc :y:
My 5k ran standard bottom end and head, 3kb carbs and manifold, 4 into 1 extractors and a 2" zorst. Ran a thermo fan, electric fuel pump and a self modded dizzy Cam was reground to a Wade 169(?) spec.
This would easily rev to 8000rpm and did so for years and was extremely competitive in club events. This is why I question buying aftermarket pistons......
