KE70+AE92 Posted February 3, 2008 Report Posted February 3, 2008 hey my 4k used to idle at 8 to 900rpm but i was revving it and i revved over it 5000 and now it idles at 2000 and i can't get it to go back down. ive check the acceletrator cable and its allright and the choke cable and its fine i also tryed to ajust the idel speed and mixture but no luck. so i don't no what the problem is can anyone help thanks Quote
LittleRedSpirit Posted February 3, 2008 Report Posted February 3, 2008 heymy 4k used to idle at 8 to 900rpm but i was revving it and i revved over it 5000 and now it idles at 2000 and i can't get it to go back down. ive check the acceletrator cable and its allright and the choke cable and its fine i also tryed to ajust the idel speed and mixture but no luck. so i don't no what the problem is can anyone help thanks There is a vaccum leak. Check all the little rubber hoses and connections from point to point, if somethings hanging either plug it or reconnect it and test. Thats all I can think of, unless somethings up with the carby. Quote
KE70+AE92 Posted February 3, 2008 Author Report Posted February 3, 2008 i check cable all pluged in when u rev it the revs don drop imediately the drop very slowly Quote
coln72 Posted February 3, 2008 Report Posted February 3, 2008 tried stamping on the accelerator pedal to make sure the linkage hasn't stuck open. Used to happen with the first set of twins I fitted. Quote
