Hey all.
ummm been discussing what to do to my 7K when it comes....
and the general consensus is that supercharging will be better?
now i've read that 7K's don't like revving?
is this because of hydrolic lifters?
thoghts anyone?
turbo or SC?
Edited by blackrolla80
Ok sweet! thought as much.....
how muchish am i looking at?
i don know wats involved in SC n a motor so i don know what extra bit you need and what the best typr of set up is!
This will be for EFI
Custom supercharger brackets
Intercooler.
Piping.
Silicon joints.
After market ECU.
Will probably need better injectors.
Tuning.
Lots more bits but i haven't done it before so i don't know what exactly is needed. Supercharged 7k would have some nuts.
Intercooler.
Piping.
Silicon joints.
After market ECU.
Tuning.
get a wild cam grind, bigger exhaust valves, get the exhaust flowing big pipes etc..
wow.
doesn't look too hard...
a bit easier than turbo i think.
expensive though!
injectors wouldn't be cheap
could find second hand SC and IC.
then silicone hoses and stuff would be pricey?
2nd hand SC and IC come by every few months, same with efi gear. silicone hose joins are fair cheap too. there's injectors for sale regularly around the traps too.
ive seen a few sc12 going around people usally sell them after they do there 4agte conversion
Injectors are easy to find and fit. I got 6x 315cc (7mge) ones for $150!
Here's a good site for toyota injector info.....
http://www.autospeed.com/cms/A_0102/articl...?popularArticle
Have a read of the turbo 4k thread in engine conversions forum, there's a lot of applicable info there.
For a 7k, I reckon you'd be better off with a stock cam and SC. Will work much better in the torque range, rather than power. That's exactly what I have planned for my *one day* 4x4. :hmm:
Soooo by using that info your injectors total can
handle around 250hp?
which is around about what?? in KW?
Ok a mate has just offered me two 1GGTE twin turbs for 1700.
one has blown rings and the other has a stuffed head gasket!
Should i go with this easier conversion?
or with the 1GGTE?
how much would there be involved in the 1GGTE conversion?
or with the 1GGTE?
In a corolla ?
ALOT.
