ancullen Posted October 24, 2007 Report Posted October 24, 2007 Not that owning a Volvo is a bad thing... :) Quote
Jono Posted October 24, 2007 Report Posted October 24, 2007 especially if you drive them like this... http://www.youtube.com/watch?v=LYSXcDSHnNw Quote
ancullen Posted November 1, 2007 Report Posted November 1, 2007 Jason said: well unaware at the time i had muiltiple assiment due in the following days to yeah, got finals in 2 weeks but after that progress should start again Here it is dummied up, the best bit about cars, buiding em :P I can't wait until you're finished finals Jason - I want to see progress. Especially now I've been tempted into doing an SC14 conversion myself. Now I just need to see results to ascertain how much of your conversion I should copy. :wink: Quote
Jason Posted November 1, 2007 Author Report Posted November 1, 2007 (edited) hehe, well my throttle spliter has just been sent from the states so HOPEFULLY ill get it after my finals which will be nice. Also have to fix the brakes on the volvo b4 i do anything else to the rolla, metal on metal goodness.... and quicly bolted the manifold on without a gasket to see how it runs with new throttle.... mmmmmm delicious but have to make up a gasket.... and no more revving out to 3000rpm after cranking :P and ive good a very bad sneaking suspicion that i fuked up a ring installation.... :wink: have to look into this.... but even if i have it wont be THAT big a deal since most of the time hase been with fuking around with custom parts Edited November 1, 2007 by Jason Quote
ancullen Posted November 1, 2007 Report Posted November 1, 2007 Speaking of throttle splitters, I was eyeing off an Eaton M112 from a Ford F150 Lightning with it's standard twin throttle setup. But I resisted the urge. :wink: I hope the ring issue isn't too bad. It'll be good to see updates again, which I presume will come thick and fast once you're finished finals. :P Quote
Jason Posted November 1, 2007 Author Report Posted November 1, 2007 (edited) Me to O.O , got to get me a compression check, its just got a bit of worrying blow by :P yeah once the cable split comes it shouldnt be far away from a decent tune with out using 100L/min Edited November 1, 2007 by Jason Quote
ancullen Posted November 2, 2007 Report Posted November 2, 2007 Are you using larger injectors on your setup, or still just the 375cc 4A-GZE injectors? Quote
Jason Posted November 2, 2007 Author Report Posted November 2, 2007 the gze injectors have be proven good upto and over 200hp :P Quote
ancullen Posted November 2, 2007 Report Posted November 2, 2007 Which is fine if you're only settling for 200hp. Or do you mean 200hp at the wheels? I've got 6x 7M-GTE 440cc injectors waiting for me to finally upgrade the engine and fit them. And 550cc RX7 injectors aren't overly expensive. :P Quote
Jason Posted November 2, 2007 Author Report Posted November 2, 2007 (edited) When the time comes weres its running out of fuel ill change them, but when its dumping flames and poring black smoke under boost i think ill be right :P Edited November 2, 2007 by Jason Quote
ancullen Posted November 2, 2007 Report Posted November 2, 2007 Hmm, yeah, I suppose it'll be okay then. :P Quote
Jason Posted November 2, 2007 Author Report Posted November 2, 2007 (edited) after some thought, I'm completly scapping the dash and going for a speco speedo/tacho/oil pressure/fuel dash trying to fit the custom t18 is to much effort and looks way to dogdy Edited November 2, 2007 by Jason Quote
Jason Posted November 8, 2007 Author Report Posted November 8, 2007 (edited) ok i need some help on this. I'm completely perplexed, so i noticed when i pulled the injector rail off the fuel was orange, assuming the worst i though that the tank might be rusted. So i pulled the tank today to install my new fuel sender and had a looksee. To my surprise it was spotless! Little bits of crap but no rust to bee seen (ill get phots of my cerma later). So now the question is why is the fuel going in nice and blue and coming out scummy orangte?!?!? Now this happens as it enter the surge tank so i can only assume it coming from the tank. Unless the overflow is really contanimated and it gets washed back into the main tank. So tell me you ideas wile i contine seaching :evil: Edited November 8, 2007 by Jason Quote
ancullen Posted November 8, 2007 Report Posted November 8, 2007 Surge tank or fuel filter is all I can think of. Possibly the fuel rail??? Quote
Jason Posted November 8, 2007 Author Report Posted November 8, 2007 atm ive put it on the dogy pre surge tank filter, cost $2 will test is out later today. Quote
