Felix Posted January 7, 2008 Report Posted January 7, 2008 (edited) Quote Changing exhaust affects mixtures. Yep, fitting a more efficient exhaust system can cause the fuel mixtures to be leaner. Usually increasing the carb jet sizes slightly will fix the problem. A 2 inch system is way to big for a standard 4k. Would be better suited to a fairly heavily worked 5k. One thing I have found with sports systems... For a given exhaust, as you go to larger capacity motors with more mods, the exhaust volume decreases, but gets deeper. Edited January 7, 2008 by Felix Quote
Hurricane Posted January 16, 2008 Report Posted January 16, 2008 (edited) i had a 4k with a 2inch with a muffler and a ressy. it made more power and rev'd better running it straight outta the extractors than throght the pipe, and know it wasnt blocked, but i was running a dato 200b carby on it. wich bolt straight up. as for the corner troubles, i would say its more a fuel issue. because if it was the zorst it would do the same in a straight line. start with cheacking your fuel fillter, then the operation of the accelerator jet making shore it is spraying fuel into the carby, then set/cheack you float levels also one of my bros mates has a datto 1200, it had a 2'' zorst on it, then went to 2 1/2 and it made so much more power, even got it dyno'd but i can't remeber what it made? and its was still a 1.2litre, but it did have cam, head and carby work Edited January 16, 2008 by Hurricane Quote
greenmac80 Posted January 17, 2008 Author Report Posted January 17, 2008 well it has to be fuel float! because i installed a electric fuel pump and it made no difference! so i guess i'll have to rebuild my carby and see if that fixes the problemo Quote
billyrock Posted January 17, 2008 Report Posted January 17, 2008 i would also sugest gettin ur zorst fixed straight thru is no good. i don't even run straight thru on the drag car(s) that me and my bro have (he runs a 1980 xd falcon with a worked 351ci with ic&e dizzy yella terra heads 4 barrel holly carb and some crazy ass cam) and i run the ke70 WOOOOO STOCK POWER Quote
