dfunkt Posted December 28, 2007 Report Posted December 28, 2007 (edited) ok, this is a fair way away, and we have the GOR before it as well... ;) BUT ... i would like to test out my lil 20 since it's finally got the new heart i'd promised it months ago. and i'm sure there are a few others around that would like to see what they can do in their own lil beasties :y: so i'm proposing that we could do it as a group, all meet up somewhere on a friday arvo/evening/night, and then head on out to calder park for their legal off-street drags. gates open at 5pm with racing starting at 6pm...now i know people work and stuff during the day, and others work nights, so i'm hoping to have the date set sometime before the GOR run so that you all can take a day/shift off work and come on out. :y: as it stands, the night's i'm thinking are the 29th of feb, or the 7th of march...with the latter being "ladies night" where each competitor can bring in a lady friend for free :bash: now, the only reason you shouldn't be attending is: A- you are out of the country B- your car is dead C- you are dead thank you for your time... dF Safety Stuff (from their website) Calder Park Legal Off Street and Open Drag Racing Safety RequirementsCalder Park Racing Promotions Pty Ltd has recently reviewed the scruitineering regulations. These rules and regulations have been put in place to make Calder Park as safe and pleasant as possible for all competitors and officials. At all times whilst on the premises please abide by the rules and regulations. Keep safe and enjoy your racing. All vehicles and motorcycles must meet the Calder Park scruitineering standards. In the event of any disagreement on whether your vehicle meets the standards the final decision will rest with the Chief Scrutineer who will decide if your vehicle is safe to race. Remember at all times we are only looking after your safety. General Rules and Regulations: All vehicles require the following items: • Radiator overflow bottles • Accelerator return springs • Batteries must be securely clamped • Appropriate braking systems • Appropriate steering systems • Plugged holes in firewall • No loose items inside the driver/passenger compartments. All other items must be secured inside the vehicles boot/trunk • Plugged rear parcel shelves / rear firewalls for any vehicles using N2O • All vehicles using Nitrous Oxide must display on the outside of the vehicle in the area where the bottle is located the approved sticker. In addition the approved sticker is to be placed on the outside of the windscreen in the top left hand corner • The approved sticker is yellow with N2O printed in black • All competitors must follow all speed signs and officials directions at all times. Speed/burnouts are to be kept to their appropriate areas at all times. If you fail to obey the rules you will be asked to leave the premises. Licence: A current driver’s Licence is required. Learner’s permits will not be accepted under any circumstances. Drivers seat: It is mandatory that all seats are firmly attached to the vehicle. Seat belts/ Harnesses: Vehicles running 11.99 or slower require a minimum quick release 3 point lap sash seatbelt complying with the current Australian Standard. Vehicles running 11.98 sec or 110 mph or quicker require a minimum quick release 4 point harness complying with the current Australian Standard. Any vehicle running between 130 mph or quicker requires a 5 point harness incorporating a crutch strap. Safety helmets: All racers must wear Safety Helmets when entering, racing and leaving the race track. Please wait until you have stopped your vehicle before removing your helmet. Safety Helmets must comply with the current Australian Standard. For those of you who do not possess a Safety Helmet, you may hire a helmet through Calder Park administration office. Roll Cage: All vehicles running 11.00 sec (1/4 mile) or slower are not required to have a roll cage fitted but may be fitted if you wish to do so. All vehicles running between 10.99 sec & 10.00 sec and under 140 mph (1/4 mile) must be fitted with a single roll over hoop. A hoop covering the full width of the driver’s compartment with 2 bolted back stays and a bolted intrusion bar. Utilities may use a 4 point roll cage with intrusion bars/diagonals on both sides and single diagonals in main roof hoop. All other vehicles running faster than 9.99 or 140 mph are required to be fitted with a full 6 point roll cage. Vehicles, where the body may be separated from the chassis/roll cage in an accident, mesh or net, are required to be fitted with a roll cage over the driver’s head in order to retain the driver’s limbs within the cage area in the event of a roll over. Parachute: All vehicles reaching 140 mph must be fitted with a single chute Open cockpits: Convertibles, roadsters and any other open cockpit vehicle are required to be fitted with a single rollover hoop covering the driver’s compartment. Tail shaft loop: All vehicles running 10.99 sec or quicker are required to be fitted with a tail shaft loop. The tail shaft loop is to be made of metal, a minimum 3.2 mm (1/8”) thickness and 51 mm (2”) wide securely mounted and located within 15.2cm (6”) of the front universal joint. Wheels and Studs: Hub caps and clip on wheel rims must be removed before competing. Scrutineer’s will check for loose wheel nuts and cracked or damaged wheels. All vehicles are required to be fitted with the minimum of wheel studs as original manufactures specifications. All vehicles are required to have wheel nuts on all wheel studs. Each wheel stud must protrude past the outer face of the wheel by a distance no less than the diameter of the stud used. Vehicles running quicker than 10.98 sec are required to be fitted open ended wheel nuts. Factory alloy wheels may use original nuts/studs. Tyres: Tyres of the same construction are required front and rear, vehicles using rear slick tyres are required to be fitted with front conventional non radial tyres. Protective clothing: All drivers and riders are required to wear full covering. I.e. long sleeves, long pants, socks and closed toe shoes. All Motorcycle riders must wear protective leathers, an approved Australian Safety Standards helmet, riding boots and gloves. Race suits are required for drivers of vehicles that have manufactured firewalls, front floors and non factory design windscreens. I, ________________________________________________________________________________ _____ hereby agree that I have read and understand all of the above rules and regulations set out by Calder Park Racing Promotions Pty Ltd. I acknowledge that the Chief Scrutineer and/or his delegate have the right to stop my vehicle from racing due to any safety concerns at any stage during the event. Refunds will not be given if safety regulations are breached either directly or indirectly. Signed: __________________________________________________________ Date: ________________ Edited January 10, 2008 by dfunkt Quote
kickn5k Posted December 28, 2007 Report Posted December 28, 2007 ok, this is a fair way away, and we have the GOR before it as well... :y: BUT ... i would like to test out my lil 20 since it's finally got the new heart i'd promised it months ago. and i'm sure there are a few others around that would like to see what they can do in their own lil beasties ;) now, the only reason you shouldn't be attending is: A- you are out of the country B- your car is dead C- you are dead thank you for your time... dF Hey man thats probably about the time i was going to be pulling the ke-11 off the road to do the supercharger and EFI conversion. May have to put off that as it would good to get a time to compare, I'm in. Oh and i finnish work at 2:30 on fridays so it should be sweet. Tate i recon we should try and get a heads up race 5k v 5k. stu. Quote
kangaroosa Posted December 28, 2007 Report Posted December 28, 2007 (edited) I sold my 5K yesterday. The rotor is going in during January, so depending how that goes i'm not sure if my Rolla will be there. Edited December 28, 2007 by kangaroosa Quote
dfunkt Posted December 28, 2007 Author Report Posted December 28, 2007 congrats on the sale roosa...i was trying to talk the gf into buying it for herself :y: i don't think your corolla would be a fair match for the majorty of us, but it would be great to see what it could do, here's hoping all goes smoothly with the engineering and conversion. stu, i'm sure we could race side by side, and i'm sure that you'd beat me, but i wouldn't care...cos mine has "the hektik side-pipe bruzza" HAHA ROLF can you try and get webers, poz (if the ca18 4x4 is running) and shane out here also... hmm, will they let us run 3 wide?! 2 5k ke20's and a ke11 5k would be hilarious down calder... dF Quote
MRMOPARMAN Posted December 28, 2007 Report Posted December 28, 2007 i was plannin to have a go in breanna before then.. guess ill have to hold off and do some 'tweaking' for this occasion.. consider me there! Quote
TheNOBBLER[RL] Posted December 28, 2007 Report Posted December 28, 2007 Hmmm... I might tyr to break into the 19second zone in the Val! hehehe... at least it will look good doing it! Should have the carbs on by then and the mufflers changed too... can't wait to change the note again. COunt me in... Might see if Deano will bring the '55 Chev along too... Quote
webers4x48 Posted December 28, 2007 Report Posted December 28, 2007 (edited) Ill try and get the night off. Just let me know which night. I'd love to see to what SECA would run. :dance: Edited December 28, 2007 by webers4x48 Quote
deathsminion Posted December 29, 2007 Report Posted December 29, 2007 I'm in too! See if I can break into the 12s this time. Quote
Sim Posted December 29, 2007 Report Posted December 29, 2007 if my wagon wasn't in a million pieces i'd bring that, but it won't be finished for a while! i'd definately be interested once its on the road though :dance:. Quote
pozman Posted December 30, 2007 Report Posted December 30, 2007 mmm, thats a fair slap with the dualing glove, looks like ill have to show you how fast 4x4 rollas can be :dance: Quote
TheNOBBLER[RL] Posted December 30, 2007 Report Posted December 30, 2007 Just remember to take off the all terains first... Quote
Clown Posted December 31, 2007 Report Posted December 31, 2007 Myself and a few mates will make the trip up from ballarat for this! Quote
Clown Posted December 31, 2007 Report Posted December 31, 2007 Mates will have a car trailer by then, so if the conversions still not done on the corolla, i might chuck the mr2 on the trailer and see what she'll do! Quote
deathsminion Posted January 6, 2008 Report Posted January 6, 2008 Just bought an AE92, so I might be up for a night of 18 second passes :P Quote
kickn5k Posted January 6, 2008 Report Posted January 6, 2008 (edited) mmm, thats a fair slap with the dualing glove, looks like ill have to show you how fast 4x4 rollas can be :P Is this the bastard child that you have in the driveway or your slowcar towcar? its just that its hard to pick which ones which as the ride heights are close to the same. haha. Either way do you really want to be on webers list"that will make two of your cars then", thats why ill wait to race him at calder when the boost is in. stu. Edited January 9, 2008 by kickn5k Quote
