  • Replies 707
Jip!
yeah mate engine bay is getting painted phantom black with a custom pearl.
ecu will be behind x member as ryan said.
Raven: yeah it was a possibility but where the wires are coming into the car it was easier to mount there.
Mr AE71: hmmm this car will not be carrying more than one passenger at a time very often at all.
also i'm probably going to be making a cover for it that way if kicked it won't matter.
when my car was going before i hardly ever had passengers.
also being right behind that x member it hangs over the footwell only slightly. so i doubt that peoples feet will even get to it anyways.
KE30_KE35_KE55: it was painted with Jotun full gloss high temp 2 pack!
thanks guys for the airbox compliments. i have finished it but....
i'm not happy! its waaaay to heavy! 3.8kg!
i've also found out you can mig ali with the right wire and sheild! turns out we have the sheild at work.
my gf's dad has enough ali for me. so all i need to do is source the wire!
so a new one will be made soon i hope! this one will be a tester!
ok all bay wiring re routed and stuff!
here is a quick shot of hw little wiring you'll see!
well pretty much nothing!!
coil igntior etc all inside the car.
alarm relays etc inside the car as well.
Edited by greenmac80
Jase: I'll talk to you later about it. Lets just say you might have some more project car/workshop space in a few months. If you behave :|
Yes i'm on solids guys, keep it on topic tho... geeez.
Nice bay Luc :) Can i see your trunk?? :D
EDIT: Actually I don't want to see any pics... I think i've seen enough on your phone :|
Edited by Jason KE30
Nice bay Luc ;) Can i see your trunk?? :D
I REALLY don't think you of all people should mention trunk and what you've seen on Lucs phone in the same post :)
  Tume said:
Nice cup holder :) .
Need to down another to make a pair of squishy struts :)
  Quote
Hey mate, just in case youre unaware, you need a very high powered welder to weld alloy nicely, eg 3 phase.
It also helps very much to have a wire feed in your hand piece, as the alloy wire prefers to be pulled rather than pushed.
