davek_14 Posted December 2, 2007 Report Posted December 2, 2007 Hello to all, I have not been very active for a while, working in another state cramps the style a bit!! I have just spent the weekend swapping over a 4K engine and 4 speed manual from a Ke55 into a Ke30 auto. I have everything in, except the gearbox bracket from the Ke55 does not line up at all with the old automatic bracket position in the Ke30. Has anyone done this conversion, I assume it is common?? Do I need a manual gearbox bracket from a Ke30 or is it something that has to be made up?? Any help would be appreciated. Cheers David Quote
sammo[RL] Posted December 2, 2007 Report Posted December 2, 2007 2 speed or 3 speed auto? 2speed cross member is the same as manual, but the later 3 speeder is very different! Quote
davek_14 Posted December 2, 2007 Author Report Posted December 2, 2007 2 speed or 3 speed auto? 2speed cross member is the same as manual, but the later 3 speeder is very different! Thanks for the reply, it is the 3 speed (trimatic) gearbox. Quote
Clapped out Posted December 2, 2007 Report Posted December 2, 2007 (edited) Hey there fella, it sounds like your one of the unfortunate guys that has a ke30 with NO BOLT HOLES for a manual crossmember? (underside of tunnel), only has the holes for the auto crossmember?, cheers phatke30! Edited December 2, 2007 by phatke30 Quote
davek_14 Posted December 2, 2007 Author Report Posted December 2, 2007 Hey there fella, it sounds like your one of the unfortunate guys that has a ke30 with NO BOLT HOLES for a manual crossmember? (underside of tunnel), only has the holes for the auto crossmember?, cheers phatke30! That sounds like what I have, is there any way around it, or am I stuffed??? cheers dave Quote
Rolla__Boy Posted December 2, 2007 Report Posted December 2, 2007 You will have to get a custom cross member made up...or get the mounts welded to the underside of your car. Quote
davek_14 Posted December 2, 2007 Author Report Posted December 2, 2007 You will have to get a custom cross member made up...or get the mounts welded to the underside of your car. thanks for the replies everyone. Rolla Boy, where is a good place to get a custom cross member made up in Canberra??? cheers Dave. Quote
Rolla__Boy Posted December 2, 2007 Report Posted December 2, 2007 Possibly want to try contact Gareth Paton...as far as I am aware he does back yardies...and he is an absolute genius with all things CAR Quote
davek_14 Posted December 3, 2007 Author Report Posted December 3, 2007 Possibly want to try contact Gareth Paton...as far as I am aware he does back yardies...and he is an absolute genius with all things CAR Thanks for all your help- will give him a bell. Cheers Quote
