Use an electric solenoid on a switch in the dash. Then it doubles as a number plate hider for when you may require one.
....and because you have the fuel filler there it would be easy to get out of if you every get pulled over by :( . "Sorry officer, I just filled up with petrol and forgot to flip it back up!" :)
man your a legend!! you weren't joking about the rear quarters being hard!! done lots of filing sanding... whoops too much off redo again etc etc.
i reckon i got one side done but still got one more!!
you gonna do any bay work?
....and because you have the fuel filler there it would be easy to get out of if you every get pulled over by fuzz.gif . "Sorry officer, I just filled up with petrol and forgot to flip it back up!" 07-nyahnyah.gif
Interesting concept :) :) although i have tried the "sorry officer" line before without success.
Yep, they are so annoying, mine are pretty good now, but the hours it took of panel beating, and filing.........
i don't even want to start counting :(
Good to see you're not discouraged though, keep at it :D
The bay will get done when the new motor or C4 goes in, I'm not sure when that will be though.
It may be after rego, or during the build, depending on how long this paint takes.
Have rdo today, so i took my bottom end bits to PLR machine shop.
Things i gave them to do:
Linish crank
Line hoan mains
Torque plate bore
Balance engine
Deck block.
Will get it all back in two weeks, and will begin assembly.
Will post prices up on here once i pick up the bill.
The commo all loaded up.
Still waiting on welder, so progress on the shell has halted :bash:
Long term goal is to run a 9 sec pass and still be 100% street legal,
the moroso calculator says i need 480 hp at the flywheel to run a 9.9, so that is the immediate aim.
After that i need to spend many many moons, attempting to set the car up in a way that will get the power to the ground.
Therefore the plan to go C4 auto, ect, ect....
Moved the 30 from the oldies house to my house finally,
mmmmm spacious garage!!!
Have been doing a fair bit of welding, seams/ rust/ badge holes ect.
Also got my stuff back from the heat coating place, so shiny!!! cost $300
still waiting on engine back from the shop, should be next week i recon.
how good do the manifolds look with that coating!!!?
Yeah Jono
Matt's attention to detail is an inspiration to us all...... ;)
Can't wait to see this car again once it's all finished.......... :D
Then he can start on the Crown, that thing will be unique i'm sure........... ;)
^^ thanks doug, youre a champ.
The coating actually looks that good in real life too, it is seriously cool, a polished alloy type look.
I think in the coming 6 months i will become a very regular customer.
Forgot to bring my camera today.
Have finished all welding, and the whole car is in etch.
My old etch used to be grey the new tin is scum green, so it looks a bit patchy. :P
Working hard at getting it straight enough to undercoat,
getting close, i just have the edges, and the more detailed bits to deal with.
Have not heard from PLR yet about my motor,
but i forgot to give them my harmonic balancer, so that was a delay for them.
looking at ordering my new suge tank this week too. :P
Ok, finally some new pics.
I have been working every arvo for a few months now.
I got my bottom end back from plr,
had full balance crack test, line hoan, torque plate bore, crank grind ect ect. $960.
sitting in the spare room atm until i can get a clean spot to put it together.
sent the quads off to get heat coated too.
Also spent a bit of time porting them to remove some of the casting edges and improve flow
also disassembled my door handles by grinding the pins off, and sent them to the chromers.
Had to paint strip them as well because of previous colour scheme. They will be back in 2 weeks.
Have also spent many many more hours on the bodywork,
and the whole car is now in undercoat finally, and is looking real straight so far on the final rubdown.
Will start on my bumpers soon as they need a bit of brass work before they hit the chromers. :bash:
