ok I have a 4k with twin asian carbs .The car starts and idles fine but after reving
it up it goes back to idling then dies.It is also only running on the front two
clyinder when idling any ideas?cheers
Just check the following it may help.
Vacuum leaks, test , clamp brake booster and PCV hoses to test
is one of the needle and seats stuck?
Have you connected both fuel cut offs up?
is one of the secondarys stuck open.
Edited by KE30_KE35_KE55
