Snapped one bolt that holds the camshaft caps down, Once rectified it was back together quickly. Cam timing has been set and lines up fine.
Dizzy has been put back together with new seals and roll pin.
The ARP head studs stick out further than the standard bolts so the dizzy gear was touching it, 3 hours later it was fixed.
Des :lolcry:
  • Replies 196
It sucks even more when you stuff up the thread in the head.
^^^...then you can buy a 4agze front cut...
He already told me he don't wanna.
ITS ALIVE.
Brian at work gave my car a polish in which i thank him a lot for, He spent a good 2-3 hours polishing my seca when he could have been getting drunk with every one else.
Drive great and stops well considering the rotors are covered in surface rust.
Getting a RWC soon as i can afford the rego.
Today it received 2 new Falcon ziex tires.
Now rust free.
Borrowed a rear wiper blade off Trevor till i have time to go to the wreckers and get one.
Received a standard din tray thing in the mail today from Beejae82 :y:
The only thing i would like it to have now is a cd player and I'm happy for now.
don't knock my bog work, Its pro.
lol, not too bad considering you are from bogandesert :y:
I took too much bog off when i was sanding back, Other than that it would have looked ace. Stupid spray filler can was shitting me, Kept clogging up and spraying big blobs.
