i thought that some are plug and play (CSi/SR5 upgrade - source the cluster from an AE95 SR5 wagon its identical to the SX/GTi cluster but without the extra gauges, it doesn't look as tacky, if you compare the two you will see what i mean) but replacing your SE spec gauges with the SX/GTi setup is a royal pain in the ass. You need to strip, swap and add a far bit of wiring so I'm told
the tacho cluster in the lower spec ae92's are plug and play.
the sx/gti cluster arent because they have a different plug setup. yes the swap can be done but its a case of cutting and splicing to fit.
also with the sx/gti cluster you need the oil pressure switch just so the oil pressure gauge works :P
ill grab the wiring diagram off www.twincam.org when the forums up again
Edited by MYSTIK
