hello to all
my 4K is leaking trough the oil pan gasket and i have to change it
my question is... do i have to remove the engine form the engine bay or i can change the gasket from below???
thats it, thanks in advance
Sebastian
Thats pretty much what you have to do. I might have dropped the cross member as well, can't remember. Seriously, just take the engine out, you will regret trying to do it with the engine in.
well following your advise i lift the engine to change the gasket, but one nut didnt colaborate so i have to remove the engine
and as is said in the rollaclub faq i increase the oil pump pressure as well
i have no pics of the first part :D
so here we go
it looks good
not the best place to put an engine, but...
there is something missing here
check out the gearbox :sob: :o
the competition extractor :evil: :(
the starter
new gasket in
my help, my grandfather 89 years old
after 8 hours its back in
BONUS
a 4Kless *E70
the new Corolla "Powered By Trufaz"
  • 8 years later...
Don't do it up so tight Bulant, and if you take it off use a silicon sealant on both sides.
I think the common problem is to screw them up so much it squeezes the rubber out, but overall its not a brilliant design. A rear leak is very common, and the hardest to get to if you want to fix it.
