bridgeport Posted September 26, 2003 Report Posted September 26, 2003 use the a series crossmember from a rwd levin i know that much what gearbox do i run t50? what diff and driveshaft ?? will i use the same selector stick? and hydrolic clutch??? radiator capable of the engine? just a stock bluetop
Medicine_Man Posted September 27, 2003 Report Posted September 27, 2003 As long as you already have a 4A-C block everything should bolt up pretty much the same..
Redwarf Posted October 3, 2003 Report Posted October 3, 2003 Virtually identical, except one has a longer stoke than the other, and (I think) the block is 10mm higher. Bolt in change over, although use the original flywheel and clutch if you can. you can use the later one, but it requires a small amount of farting around with the clutch fork and cable. The hard bit is finding a decent 4K these days. Cheers R
rjenman Posted September 29, 2005 Report Posted September 29, 2005 how much wood would a woodchuck chuck?
