hello again guys...on my ke20 i am in the process of puttin 17x7.5's on it.. on the front the left wheel sticks out about 3/4 of an inch more than the right one? and ideas? thanks
I can draw on extensive experience of bending 20 series Corolla's.
I had the same problem a while back and it was fixed by changing the engine cross member.
Other causes could be bent LCA, or buggered ball joint (doubtful)
yeh thanks guys I'm pretty sure all the bal joints are stuffed but i have to take the wheels of when i get a chanch and make sure spacers are exactly the same size. whick I'm pretty sure they are the same...and i will have 2 make sure there is the same clerarance from the wheel and strut...
