drain the oil out of your struts and refill with a heavier oil.
cut the springs (yes I said it :D)
find some ke26 rear springs as the main leaves are thicker
thanks coln72 i will look into that..ive just got to get wheels and everything all the same and then get it down! cheers and redwarf I'm just finding a cheap easy way because i have other things to worry about at the moment than good suspension. what is good suspension for a ke20 and around what price range? cheers guys
Edited by poodle
Something I wouldn't do to a road car but you could also redrill the crossmember to move the lower control arms out an inch for more camber.
