Hi i keep reading about a pajero master cyl that fits these kes anyone know what model they come off, any pictures, are they shorter, all help appreciated
Yeah ive heard of this being done before, although i can't confirm ive seen it on a rolla, what i do know is a mazda 121 master and booster fit straight up to a rolla, only modification is fabricating new brake lines from the master to the "T" piece on the firewall, i had this setup on my ke55 when i had it, also got a reco setup (mazda) sitting in the shed............somewhere, if ya interested I'm willing to sell it............cheap!
cheers phatke30!
Yes a ng pajero master cylinder will bolt up to the ke30 booster but not the ke55 one.
see here :D
big white cap. :D size is 15/16th you can get smaller bore size ones from galants and evos.
see here :D
many thanks guys thats all i needed
  • 4 months later...
No none to the booster. As long as its a ke30 booster it will bolt up.
I'm about 90% sure the rear brake line will bolt in but you will need to get a single banjo fitting for the fronts and possibly re-bend or get a longer front brake line to where it goes on the firewall.
