I am turboing my 20 valve and am at this stage looking at a Stainless manifold and a brand new t3/t4 turbo kit including intercooler piping waste gate everything i need but i am not to sure if the t3/t4 will be to big or not if it will be is there anyother better suited turbo out there please note i am only going to run around 6-8psi. I have a microtech and stuff so that is not the prob. Will be drifting lapsprinting and in the motokhana. Cheers guys
t3/t4s are very old technology and stainless is a terrible material to make manifolds out of. Get a turbo from the newer Garrett GT lineup and a steam pipe manifold.
Most of those "ebay special" turbo kits are junk. a T3/4 is a big turbo, running low boost you could get away with a GT25, about half the size and will come on under 4 grand.
A 16V exhaust manifold will require modification to bolt up the the 20V Head. 1 hole needs to be notched, the other needs a metal tag welded to it and a new hole drilled.
Those manifolds crack like nothing else, look pretty, but they've got too many joins.
Try and get hold of one of these cast HKS, or a recently available copy.
HKS turbo manifold - Was quoted $90 freight.
HKS copy manifold
  Taz_Rx said:
20v's have the same exhaust port flange as a normal 4age!? If so.....
http://cgi.ebay.com.au/ae86-4age-turbo-exh...1QQcmdZViewItem
With that manifold you can use a t2, t25, t25g, t28, gt28, gt25, gt28rs etc etc etc.
more than just the two inner studs are the same, its just the two outler holes that are different. How do I know? well lets just say I have converted a 16v flange to a 20v and a set of extractors to suit both.
oh also theres a huge about of turbo 20v info on toymods.net
Edited by Sam_Q
  Quote
I wasn't going to bring this up, but If you both would have read the whole post I wrote you'd know its been covered.
hey guys thanks for the comments. I am now looking at the smaller turbo for now the t25 item you suggested so that is sorted. To the other guy in Darwin can you send a PM with your details as i would love to come have a look at the manifold you have cheers guys
