SKA80R Posted September 21, 2007 Report Posted September 21, 2007 (edited) Can anyone tell me if clearance is a problem in putting a 7k into a ke70? I have put a 5K in a KE70 before and i know the sump clearance was was next to nil. Can a 4k sump be used if there is a problem? Can all of the 4K components bolt straight on ( Inlet, exhaust and box and flywheel) Cheers Dave Edited September 21, 2007 by SKA80R Quote
Raven Posted September 21, 2007 Report Posted September 21, 2007 (edited) Your main concern is the engine is taller. I've seen people mod the sump and oil pick-up before. Might be worth searching the site and seeing what information you can find. :P Edited September 21, 2007 by Raven Quote
78_7kRolla Posted September 22, 2007 Report Posted September 22, 2007 No mate, a 4k sump cannot be used as it is too skinny. you will most likely need to cut/mod the sump to clear the crossmember. Quote
