doobism Posted September 17, 2007 Report Posted September 17, 2007 Hi guys Haven't been able to find this info going through the forums already... My engine isn't sparking, and we need help! already checked the coil, dizzy shaft, and looking at the module now (there's some kind of leak in the dizzy that maybe fried the module)... Can't work out what engine is in it- its an 1986 AE82 rolla with an imported 4AGE engine, that's been installed previous to us getting it. Engine has black writing with red eg TOYOTA 1600v TOYOTA 1600 (i forget what it actually says) I can provide more info if it helps... What else do you need to know? Any other advice is more than welcome.. Quote
Des Posted September 17, 2007 Report Posted September 17, 2007 Most likely a Bigport 4age 86kw. Does it say TVIS on the inlet manifold or does it have lines in the casting ? Quote
doobism Posted September 17, 2007 Author Report Posted September 17, 2007 excellent, thanks mate. i'm a bit of a rolla noob. just out of curiousity, what's the difference between the red and blue writing? Quote
Jono Posted September 17, 2007 Report Posted September 17, 2007 don't trust the writing. late model bigports as found in aw11's had red writing. Quote
doobism Posted September 17, 2007 Author Report Posted September 17, 2007 thanks for the help guys. I'ma try get some pics up in the forums tonight Quote
Trev Posted September 17, 2007 Report Posted September 17, 2007 Black and Red top bigports were the 88kw version. Quote
Jono Posted September 17, 2007 Report Posted September 17, 2007 do those ones have the 7 rib block trev? Quote
Trev Posted September 17, 2007 Report Posted September 17, 2007 do those ones have the 7 rib block trev? Yeah they do. Quote
doobism Posted September 18, 2007 Author Report Posted September 18, 2007 thanks guys maybe a dumb question, but where the hell is the module? is it inside the dizzy? has anyone got a link to a manual, we're working a bit blind atm. Quote
tolisspi Posted February 27, 2008 Report Posted February 27, 2008 And the blue and black letters how many hp? Quote
frosty Posted February 28, 2008 Report Posted February 28, 2008 And the blue and black letters how many hp? Read and then read some more http://home.clear.net.nz/pages/phil.bradsh...0into%20RWD.htm Quote
Trev Posted February 28, 2008 Report Posted February 28, 2008 Read and then read some more http://home.clear.net.nz/pages/phil.bradsh...0into%20RWD.htm Its actually 115hp (ADM) & 128hp (JDM), Alot of people including myself get confused with the power outputs at 1st because of info like this. Quote
