My IP car is nearly finished and I thought I would post a few pics of the car. I got the car late last year off KE25 Racer off here. I have installed the Blacktop, modded the brake and clutch pedal, redid the struts for more travel and Koni yellow inserts. Had the whole car rewired and had the engine bay, interior and boot resprayed. Still have the body to go.
The car specs are
CAR: Toyota Corolla # 25
WEIGHT: 800kgs
ENGINE: 4AGE 20 Valve Black Top
OUTPUT: 185hp at the flywheel
FUEL TANK: Standard with a surge tank
BRAKES: Front - Nissan Gazelle Rotors with JFZ 4 spot calipers
Rear - Mazda Rotors with Mazda 1 spot calipers
TYRES: 3J Improved Production Car Yokohama control tyre A048r 185/60/13
TRANSMISSION: Toyota T50 5 speed
DIFFERENTIAL: Toyota T series with 4.77:1 TRD LSD
WHEELS: Performance Globe 13 x 5.5-inch
SUSPENSION: Custom struts, reset leaf, Koni shocks
Heres a few pics of the build
When I bought the car
Brake pedal mod 60mm over to clear trumpets
Firewall side with 10mm brace plate
Engine being dynoed
Front strut
Engine Bay
Dash
First time on the track
The car is going to paint in a few weeks and will be white in colour with blue racing stripes with the same livery as the brothers KE20 hers a pic of the bros KE20
Edited by toyocharged
  • Replies 53
You'll probably find they've used a T housing from the narrower early Celica's. From rumours I've heard you need to shave the axels at the spline end to make it bolt together with an LSD carrier, unless its a CUSCO.
Terrific car. How have you found the 4.77 final drive ratio? I'm considering that ratio for my own car. I really like your heat shield over the exhaust. Must do something similar for mine. Can you get your brother to post his car too? I know brothers are competitive but this takes the cake. :D
I actually havent installed the 4.77 yet I'm running a 4.11 which is way to tall for Mallala, only using 3rd gear, my brother runs a 4.55 and thats seems alright. Hopefully a 4.77 will be perfect, we don't use 5th but if we ever go to E.C or P.I 5th will be used.
heres a few pics of the bros car, hes not really into the interwebs :D
Specs on his car
OWNER/DRIVER: Craig Sharp
CREW: Clint Sharp, Rob Sharp, John Sharp
SPONSORS: Cooper Auto Electrics Co & JAS
HIGHLIGHTS: Finishing the car
E-MAIL: cooperautoelectrics@bigpond.com
CAR: Toyota Corolla # 77
WEIGHT: 800kgs
ENGINE: 4AGE 20 Valve Silver Top
OUTPUT: 165hp at the flywheel
BRAKES: Front - Nissan Rotors with JFZ 4 spot calipers
DIFFERENTIAL: Toyota K series with 4.55:1 TRD LSD
SUSPENSION: Custom struts, reset leaf, Koni shocks, adjustable panhard rod
Link to Craigs car
http://www.iprasa.mx.com.au/cars/77%20craig_sharp.htm
Link to Clints (Nephews) car
http://www.iprasa.mx.com.au/cars/15%20c_sharp.htm
Link to Robs ( Nephews) car
http://www.iprasa.mx.com.au/cars/51%20r_sharp.htm
heres some pics of the JFZ brake conversion, we had to make new brackets up because the JFZ have a 5.25 inch bolt pattern, using Gazelle rotors with a adapter plate for correct offset, we made the bracket first from tin and when the final offset etc was correct. We got new 6mm mild steel laser cut to suit, we also added a 7mm spacer on the rear of the spacer for the correct offset and drilled and tapped it to suit a 10mm dia high tensile bolt. We got the pedal sussed and they feel good. Next weekend will be the test, fitted the new Konis they are Fiat 124 and need a bigger diameter hole drilled 10mm and shaved the bottom bush to suit the shock mount.
John
Track day with small video, shock horror the brake conversion worked
Brakes worked fantastic, dropped 2 secs a lap straight away down from a 29 to a flat 27, didnt fade, plenty of bite, car needs still more rear brake. Might try a different bias adjuster had mine full rear and still needs more. The new rear Konis have got rid of the nervousness from the rear Thought I was flying round, nephew took it for a spin and did a 1.25 flat then a mid 24, he rekons a high 22 is very acheivable He was braking probably 100 metres latter than me everywhere and on the power a lot earlier everywhere. Lap record for Mallala is a 1.25.1 for class D U1600, so the car has plenty of potential. I just need to learn to drive faster . Car goes to paint on Thursday, then its stickered up and ready for action
Courtesy
www.mallala.com
Class
Improved Production
D U1600 Rob Hankinson (DATSUN 510) 01:25.1
Heres a vid of it from the northern to turn 1, mate's chasing me in his RX4 IP car with 13 Bp in it, you can hear the quad ITB's down the start/finish straight then his rotor noise takes over. He had me on the straights but I got out the corners that much quicker I always gapped him by a couple, he' much later on the brakes than me, I still not fully confident with them yet
http://www.youtube.com/watch?v=5_GDqNw-JMs
  • 4 weeks later...
The rolla is finally 1 colour
heres some pics, wife emailed me some pics today, I'm 800 kms west of Adelaide :P Pick her up friday Pics arent great will get some when its back together. The wife says the paint looks good in the flesh
Will have the same livery as the nephews KE30 but in a blue
dude, very nice, i love them both
how easy are those TRD diffs to get, and what are they worth?
cheers and keep up the good work!
