hiya boyz and girlz, I was looking at some info on the 2zzge and I know that lotus used this engine in a MR lay out, but has anyone seen or know of any one that is in RWD lay out? Maybe in a rolla.
Thanks
Chris
One of the companies that make Lotus 7 replicas has a version available with the 1ZZ-FE and the 2ZZ-GE. But it uses a Ford 5-speed gearbox. :D
Edited by ancullen
  rollamods said:
Craig from Extreme Custom Engineering at Coopers Plains in Brisbane has done a RWD 2ZZ recently. Custom bellhousing, custom mounts, custom exhaust, quad throttles etc
  Nitephyre said:
PICSORBAN! :D
What he said, Sounds insane.
what stops me from looking into this further is rebuildability issues and weaknesses that the engine has. I will still with my 4AG/F power till then.
  JC807 said:
is this with a custom bellhousing ($$$) or does it magically all line up?
I think it's with a custom bellhousing. I presume they bulk buy them for the Clubman kits.
  • 2 months later...
what weaknesses???? please do tell
Probably not done often as Toyota already has a similar, higher-spec engine already set up for rwd duties; the BEAMS 3sge from the JDM RS 200 Altezza.
