Hi all i just bought a 82 KE70 5 speed and i am looking at a heart transplant on the cheap. a mate of mine has an L20 their willing to part with for free and i am wondering how straight forward this conversion would be???
any help would be much appreciated :D
go fro it man, woudl be bloody awsoem, even stokc l20's get going allright especially in a tiny little rolla, if ya can get all the aprts liek engine, box mounts bit of tail shaft and all that gear it wont take much to chuck it all in and you could do it really cheaply, the only problem you might run into is the height of the l20 due to increased stroke, nothing a bit of a bulge in the bonnet cnat fix, and you may eventually decide to go back to an l16 or an l18 and they should fit fine height wise
just my 2c
L18 is a MUCH better motor... loses a bit of torque over the L20 but loves to rev...
Problem with L motors is they require twin carbs and headers to provide any useful power... that kinda blows a hole in the budget right there.
Oh and the gearbox won't fit in the ke70 tunnel without flogging the snot out of it and cutting the chassis reinforcement away for the shifter hole.
I had one in a 1200 sedan. Yeah we flogged the snot out of the transmission tunnel. As was stated above not a bad motor. L18 does rev better as it has a shorter stroke and yes you will need to look at twin carbs and headers for more power. The best option we had was L18 block and rods with l20 crank (I think) and L20 pistons. This way we got L18 short stroke combined with L20 capacity.
Now lets just look at what you've said:
swapping cranks/rods/pistons between blocks is common place so that ok :D
However when you change to a longer stroke crank (in this case the L20) you increse the stroke, which is the whoe idea.
Jordan
P.S: spending money on a L20 is like spending money on a toyota R series engine (-RG virsions excluded, we're talking iron, non-crossflow heads here, stuff like the 2R, 4R, 18R.) It sounds like a good idea, it even feels like a good idea, and when people tell you not to it makes you want to do it all the more. However as all have found out, unless your class racing (and you're not) it is a bad idea. Especially when you have to go to the effort of swapping one into a different chassie.
Edited by Jordan
dude, you could put a 2tc or 2tg in or 3tc/2tg hybrid..
think baout it alot better and reasyer options...
t series k series and a series motors all bolt in! as do the box's and tailshafts with very minimum that would have to be spend on custom parts and hours of labor.
the money you save on the engine conversion you could be spending getting power for of the motor that just 'bolted in'
be smart go with toyota or buy a datsun for your datsun motor..
swapping cranks/rods/pistons between blocks is common place so that ok :cool:
Aha there that is why I said 'I think.' That means it was still L18 crank. It was a while ago. Thank you for correcting me. It was for class racing.
hey mate id go for it somethin diffrent the l series motors are a good motor when built right i got an l20 in a 1200 ute pushin 200 horsies at the wheels good fun! they are a tall motor so make shore you mount it right try to keep the sump bulge high as ya can.
thats my 2 bob anywayz good luck with it.
  • 11 months later...
the l20 are better than l18
its all in the flywheel
l20 more responsive than l18
both are all good engines
ive had em both in this buggy
i like l20 more
