yeah
if the bores are rusty n i can't get it started i guess il have to do a rebuild
4ac parts shouldnt be to expensive
but yeah I'm I'm hopeing that wont be needed
cheers for all yoru replyes guys!
well i got the car
and got it started n it runs well :lol:
this is what i did
drained oil, replaced oil filter and put new oil in.
drained cooling system and got a hose n put it full blast into the radiator and into wher the radiator hoses go into the motor to get all the goopy brown crap out, the guy used water insted of coolent
then put new coolent in,
also took the fuel lines off the fuel filter and let them drain, but not much came out, i coudlnt find a replacement filter so i jsut chucked the orginal one back in, put in some new fuel,
cranked over engine several times useing a socket and ratchet, chucked in my battery from my rolla
sprayed a whole heap of start ya bastard into the carby
n tryed startin it
nothign happened made click n thats it
went "f@$k you"
went over to the battery n actually tightened the terminals properly :cool:
tryed again
turned over quickly dint start
tryed again turned over quickly then started then stalled
tryed again turned over quickly started n stayed started
let it warm up for about 10 minutes idled smoothly
took it for a drive around the block a couple times
runs sweet as
idles verys moothly at about 700 rpm
cheers for all the help guys!!!!!!!!!!!11
Edited by Shizotimang
  Shizotimang said:
hey guys,
just wondering what advice you would all give to tryin to start a car that hasnt been started for a few years(in the case of the engine running fine uintil it was left)
apart from makin sure the batery has charge what else is ther to do?
such as oil? and fuel? and anything else u can think of to give maximum chance of the engine running again
all advice is welcome :D
oh and the car(s) in question are a sprinter with a 4ac and 92000 on the clock not started in 2 years and also a ke70 with a 4k and 300XXX + on the clock
so yeah give us ur tips :(
cheers
all of the above is good advise, I would also change the oil again after say 500km . oil is cheap oil left for 2 years will settle out in the sump ect you wont get it clean with a cold drain. when the car is used stop, start bumps ect it will disturb the settled muck and mix with your new oil.
