Jordan Posted August 21, 2007 Report Posted August 21, 2007 2TG is deffinitly worth the extra few $$, much better engine, efi or twin solex. Cheers Jordan Quote
Retrospekt Posted August 27, 2007 Report Posted August 27, 2007 http://www.rollaclub.com/board/index.php?s...7&hl=hybrid Just a q but how many people have used a t engine before? I'm just assuming and might be wrong but the 2tg is the pick of the bunch in aus? Or is it just the twincam head and nothing else? Quote
fusion Posted August 28, 2007 Report Posted August 28, 2007 (edited) Mate has a 2TG in his AE71 which was imported from Japan. Twin Solexs like Jordan suggested. And like someone else suggested it scares people when they see this thing move after assuming its stock :P He ended up making custom mounts for it in the end I believe. Edited August 28, 2007 by fusion Quote
D.McKiggan Posted August 28, 2007 Report Posted August 28, 2007 Hi Guys, I have built about 8 or so 2T-G / 3T-G over the years. Great engine to work on for the power you get from them. Add Webers and the wisco piston kit to the 3T block and this brings it out to approx 1940cc's. I purchased the 304 & 288 TRD cams, increased the compression to about 10.5 : 1 and ported the head out rather large (this is where the most power is gained) to get it to breath. It revs up to 8000 all day and the engine puts out about 200 hp / flyweel. Put this into a 800kg KE20 and its scary !!. Great fun on the track. DMC Quote
PHATKE20S Posted August 28, 2007 Author Report Posted August 28, 2007 Hi Guys, I have built about 8 or so 2T-G / 3T-G over the years. Great engine to work on for the power you get from them. Add Webers and the wisco piston kit to the 3T block and this brings it out to approx 1940cc's. I purchased the 304 & 288 TRD cams, increased the compression to about 10.5 : 1 and ported the head out rather large (this is where the most power is gained) to get it to breath. It revs up to 8000 all day and the engine puts out about 200 hp / flyweel. Put this into a 800kg KE20 and its scary !!. Great fun on the track. DMC OK i might keep this engine aside, after all, and buy some of those goodies. Maybe even put it into my KE10 later on... It is lighter than my KE20 also. Quote
