Gaday, I was wondering if it is possible to put the four-spoke Celica/Hiace wheels on a Ke30. I have some and have tried to put them on my car, but they hit on the brake caliper. I had given up, but I was looking on rollaclub and found a few ke's with them on, so I'm wondering if it is possible. cheers
Hey there mate, ive had this problem a few times before, if its got the simitomo (is that how you spell it?) brake callipers on the front, yes it will hit, you need to track down a pair of ke55 or 70 girlock callipers, as the girlock callipers don't have that arseoff of a "fin" hanging off the side of them,
cheers, phatke30!
Hi,
They should fit.
I also found AE86 mags look similar to these but ARE different eg center caps and so on. I feel these may fit if you get mags off an AE86 with out hitting your brakes as I feel the ae86 ones are slightly bigger when I had mine on my KE55S coupe.
Cameron
Cheers everybody, and yeh ill try and get some of those calipers cos those mags will look awsum on me car. Cheers
and buy the wheels of me with like 8mm off tread brand new tyres
I got a set you can have for $50. :y:
  tas_ae71 said:
or get spacers for them....
less work then getting new calipers
can't let the thread die without point out that it's a bad idea for any car to put spaces between your hub and your wheel. not only illegal, but dangerous.
I feel better about it now.
  anastasios said:
i think you would have to be more stupid to manage to break your wheel studs, has anyone heard of any stories from them actually breaking
Yes and i actually seen it fall off, I was a front seat passenger in my mates car and we heard a knocking noise comin from the front left so i poked my head out of the window as we were only doin 40k's and the wheel nut fell off so we stopped and i picked it up to find that the stud was still in it.
When I had some big, heavy 18inch 150 spoke wire wheels on the 4runner I managed to snap a stud. To run true wire wheels with knock offs you have to bolt on an adaptor. I didn't have the adaptor bolted tight enough and the weight of the wheel managed to move the adaptor around a bit and took out one of my wheel studs. Dodgjuana.
