decoop Posted July 29, 2007 Report Posted July 29, 2007 Ok its nearly 4 am, i can't sleep and i was thinking how cool would it be to have gilmer belt drive on my ke10. Purely for wank factor of course cos its got bugger all chance of slipping a belt. Has anyone done it?. I know u can get kits for a rotary but i wanna know if its possible to get one for a k motor. Even if its a kit with no holes drilled. anyone?(This may be a lost cause :y: ) Quote
Taz_Rx Posted July 29, 2007 Report Posted July 29, 2007 Rohan Ambrose from extreme rotaries has made most of the AR.com group buy kits. Can ask him, but I reckon you've got buckleys of him making 1 kit....well under like $500 anyway. See if he'd do a group buy on like 20 kits!! :y: Quote
decoop Posted July 30, 2007 Author Report Posted July 30, 2007 If he'll do it, who would be interested in one? Quote
tas_ae71 Posted July 30, 2007 Report Posted July 30, 2007 (edited) what about just getting the pullies and getting a belt made seporately...? who actualy makes/sells them cause my old man is after a set...? Edited July 30, 2007 by tas_ae71 Quote
Clapped out Posted July 30, 2007 Report Posted July 30, 2007 ^^^^^^^Obviously this is what your after? Quote
Des Posted July 30, 2007 Report Posted July 30, 2007 Just being pedantic but isn't it Gilmour drive ? Quote
decoop Posted July 30, 2007 Author Report Posted July 30, 2007 phatke30 said: ^^^^^^^Obviously this is what your after? yeah thats the shit!. Where did you get that? does it give off the distinctive whine? And i e-mailed x-treme rotaries and its a big no go. Quote
smacko84 Posted July 30, 2007 Report Posted July 30, 2007 (edited) AE70 said: Just being pedantic but isn't it Gilmour drive ? nup and my gearbox whine sounds a bit like the gilmer whine :y: Edited July 30, 2007 by smacko84 Quote
Clapped out Posted July 30, 2007 Report Posted July 30, 2007 (edited) Hey there mate, the only thing was with applying the gilmour drives was that i went the expensive way of it, i shopped around and i couldn't find any place that would sell the pully's individually! so off i went to the wreckers with a tape measure and found the model engines which had the similar pully off-set to the mighty 3k! lol! in the end i bought two sets of gilmour pully's, one set was to suit a holden 202 red motor, and the other set was to suit a g161 motor (holden gemini). also in those sets i bought both gilmour belts. both sets cost me just under $1000 including the two belts. So, off home i went and proceeded to apply! i used the holden 202 water pump pully for the 3k water pump, used the g161 altenator pully for the altenator (nippendenso), i had to lathe up a 2-3mm spacer to slide over the altenator shaft to get the pully off-set i was looking for.........another breath..........., had to also use loctite on the tread as i only had 60% of the origonal length, and finally the crank pully, i used the g161 crank pully, i had to machine the inside diametre hole of the pully about 1mm so it could sit flush on the standard 3k crank pully, also i had to tap 4 new threads on the standard 3k pully so i could bolt the gilmour pully to it, i drilled the 4 new holes 90 degrees to the origonal 3k pattern as the two pully patterns were different to each other, i had to use allen key headed bolts to join the two together, as there is no room for a normal bolt head! hope this helps, just let me know if ive missed something, or your stuck in understanding, and oops, almost forgot, i used the holden 202 belt, perfect length, and yes it does whistle its arse off, cheers, phatke30! Edited July 30, 2007 by phatke30 Quote
decoop Posted July 30, 2007 Author Report Posted July 30, 2007 I was just talkin to one of my mates, he owns a workshop and says he can whip me up a set on his mill. so now all i gotta do is get him a dummy engine and he'll do it. reckons 300 bux tops, so once its done i'll let you all know. Quote
Clapped out Posted July 30, 2007 Report Posted July 30, 2007 Definatly let us all know, $300 is alot cheaper than what i spent! oh the belt was $50, sorry to the mods and admin for being technical, i know this forum is a non-technical and discussion only! cheers, phatke30! Quote
chrisandliz[RL] Posted July 30, 2007 Report Posted July 30, 2007 I worked for a company "if you get perth street car mag that them on the back page" and I made them, polished them and shiped them. they sell a set for less than $300 rrp my 2c chris Quote
Taz_Rx Posted July 31, 2007 Report Posted July 31, 2007 Pencil me in for 1, maybe 2 @ $300'ish! :n: Quote
