Ha, it took me a while to work out what the hell was going on there...
One thing I don't understand is why you would tap into the rocker cover to use as an oil drain...to me its not a sensible solution.
Dumping frothy oil into the sump seems more ideal than dumping it into the head where you've got a lot more pressure going on. Perhaps this is why that engine runs such a large breather on top of the rocker cover.
