i have a spare bonnet but am keeping the metal edge , if your interested?
  puzzle man said:
Thought id give a little in site in to why Ive got a KE35.
my 1st car was a very nice KE35 coupe moss green only a bit of rust was in the rear boot (wheel arch)
as it was my 1st car i loved it so much.
heres a pic of it and my wife about 7-8 years ago..
ended up a wright off (not my folt)
ever since been looking for one good or bad,
then along came this one from Newcastle..
KE35 coupe
silver metalick (needs clear cote)
things that i need to do..
Ive got to cut the rust out of the bonnet or get a new onerolleyes.gif (no luck so far).
then see if i can fix the problem of the bonnet not laching over.
then see if i can find any other problems and go for a blue slip.
then put some clear on it.
  • Replies 35
  • 2 months later...
i was making a dash for some one so at the same time i made my one as well...
made up 4 rings and hot glued them in..
made shore that they sat right be for glassing..
then fiber glassing...
then bog..
then bit of sanding some primer and then some paint
and finished...
just waiting on my oil pressure gauge for the empty hole
  • 4 months later...
  • 1 year later...
I was going to say that car looked a little familiar, nice work on the youtube vid, came across it the other day.
I like what you've done with the grill, in the process of doing something similar with mine as it was missing some of its teeth. What did you use for the mesh part/ how did you put it together?
Well that would be wrong.
The grille is factory and it came out in the early KE35's.(1975-1977) There were NO KE35's in 1979 in Australia. And if there were they would have had a late KE3x grille. In late 1978 the KE35 was replaced with the KE55s.
Stay tuned next week for another history lesson children.
Edited by JiP
Well that statement is wrong in its self..
I said
  Quote
apparently it only come out on the 79 KE35
If I had said
  Quote
it defiantly 100% only came out on the 79 KE35
then your right to say I'm wrong.
Now
  Quote
Would you like a pic of my build plate?
As this is a 1979 KE35.
Thanks for playing, Craig
Sure I'll go for a pic of the build plate. I'll take your vin too if you wanna give it to compare it to the dadtbase
Edited by JiP
ha ha
and wile I'm at I will get you my license number, address and passport number as well..
