I think what paulie means is guards from a square front ke70 sedan/wagon will fit a square front ke70 panel van. and the same with the slant front.
So are both the vehicle you speak of sqare fronts?
well the headlights don't realy matter because I'm changing them anyway.
its a matter of length.
i havnt had the chance to compare the lenght of the front end.
are all ke70 bonnets the same lenght from the sedan/wagon/panel van or the t-18?
from just looking at pictures the t-18 and the panel vans look longer.
You don't have to measure. If the front end of the donor looks the same then it'll fit.
KE70's came out in two lots. The square headlight front end, then the updated slanted headlight front end.
Both models have different guards, apron, bumper, grille, bonnet and headlights.
Early Front
Late Front
All fronts are interchangeable between each other as they all are exactly the same from the front to the A pillar. So that's the Sedan, wagon and van. I'm not to sure about the T-18.
