lloydske70 Posted July 2, 2007 Report Posted July 2, 2007 Hey guys i was just wondering what webber i need for a 4ac? cost? etc... Thanks Quote
paulie Posted July 2, 2007 Report Posted July 2, 2007 32/36 would be alright.. webber and an adapter plate should set you back around 150 or so depending on where you look... hint hint.. an old ford...c**t**a Quote
AE71Wagon Posted July 2, 2007 Report Posted July 2, 2007 search ae71 on ebay comes up with webber adaptor plate. Quote
jamesrolla Posted July 3, 2007 Report Posted July 3, 2007 thank you !!!1 when will people learn to speel the important words 32/36 would be the way to go for value wise, you might get some small performance gains, make sure you get a 32/36 though with a manuel choke, not a water choke or an auto choke, and don't buy a 34adm or anything like that, its best to go the proper ones unless you wanna run into trouble Quote
Taz_Rx Posted July 4, 2007 Report Posted July 4, 2007 jamesrolla said: thank you !!!1 when will people learn to speel the important words :lolcry: Quote
tas_ae71 Posted July 5, 2007 Report Posted July 5, 2007 (edited) jamesrolla said: thank you !!!1 when will people learn to speel the important words 32/36 would be the way to go for value wise, you might get some small performance gains, make sure you get a 32/36 though with a manuel choke, not a water choke or an auto choke, and don't buy a 34adm or anything like that, its best to go the proper ones unless you wanna run into trouble dude chillax i have just put a 32/36 weber on my 4ac. it does improve perfomance james! i would recomend it for the cost, also remove/blockup the emissions gear while your at it. apart form the car mentioned they came on alfas, fiats and 2L cortinas. i would say 5-10hp i also have an exhaust on it which helps for the top end, a desent improvement over standard edit: i have no choke at all on mine, i manage. it was removed by a previous owner. Edited July 5, 2007 by tas_ae71 Quote
