  On 5/5/2013 at 11:05 PM, LittleRedSpirit said:
Until you bump it some day and you realise how easy all the leverage made it to snap off. Maybe cooler with a stumpy.
Stumpy would work better, plus if instead of cutting the bow of the key off you just trim it to the same width as the blade, that way it gives you extra length which can be sunk into a drilled-out screwdriver handle and set with epoxy etc, much stronger that way.
Also good idea to put a tiny eyelet in the end so you can still attach keyrings etc
these are popular mods for a while now
huge on the Ruckus scene
http://totalruckus.com/phpBB3/viewtopic.php?f=34&t=4333
http://forums.evolutionm.net/welding-fabrication/456721-diy-lug-nut-key.html
my personal fave are the lug nut
i have seen a swiss army knife
swiss-army-keys.jpg?w=580&h=386, switch blade one for the Ruckus, and doing a Spyder knife one for the Met, like this one
love the concept
do agree, recommend a shorter handle, so you don't damage the barrel
